Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius TVFM70BGP Control Panel Wiring Guide
Removed the wiring and timer / controller so I could order a replacement - only to lose my phone and the saved photo of it before in the meantime! Just need to know the colour pin-out no for each of the wires. Thanks!
Posted by Nathan Rees on
ADMIN Canada
    Top Expert:
  • Hotpoint Master
  • 41,747 Answers
  • Nathan Rees
    Nathan Rees Nov 25, 2021
    That was the first thing I tried - they refuse to provide this information.
  • ADMIN Canada
    ADMIN Canada Nov 25, 2021
    See if you can freeze frame on any of these videos? Even if a slightly different model, my thought is that the wiring will be similar.
    One further thought. Wasn't your phone backed up to Cloud Storage or Computer. All my iPhone images end up on the computer at C:\User/Andrew/Pictures/iPhone Photos/Download and can also be downloaded to a new iPhone from iCloud.
    https://www.google.com/search?q=Hotpoint...
THE WIRES MIXED UP ON MY TUMBLE DRYER HOTPOINT VTDOO TIMER
In most appliances I've had apart there is a stick plasic envelope stuck somewhere inside the cabinet or the control panel that contains the wiring diagram.
1helpful
2answers
Hotpoint Aquarius WMAL641 Washing Machine programming dial
see the cause:To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
God bless you
2helpful
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Dear Sir I need a wiring diagram for a Hotpoint Aquarius washing machine as have lost notes on disconnection. Thanks Paul
did you open the control panel up? inside the control panel there is usualy a wiring schematic.... otherwise i need the model # which should be located onthe backside of the machine or sometimes under the lid, in the back....
1helpful
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Hotpoint wf541
ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
Paul Carew
Vernon Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
