Hi Jane, water in the bottom of the dishwasher results from clogs in the filter or in the drain hose. Please make sure that you have disconnected the appliance from the mains before cleaning the filter! If your dishwasher is displaying an error code please check the meaning of the error message.
https://www.justfixed.co.uk/bosch-dishwasher-error-codes/
Good luck
Best,
Dave
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
