Question about Vizio Televison & Video
Vizio LC420DUG-JFR1 Replaced LED strips now picture fluctuates.
I replaced the LEDs on this unit back in 2017, so when the same symptoms of black screen with sound happened again, I performed the flashlight test. I could see the picture. I ordered the LEDs from the same source and installed. They all lit up and were working, but I did notice they seemed to be getting slightly brighter, then dimming slightly. After putting it all back together carefully and and hooking it to a video source, the picture intensity / clarity keeps changing approx every 3 seconds Like the LED intensity is fluctuating up, down. The picture is clearly visible but the white areas have gray lines through them, then they slightly soften as it fluctuates and the lines disappear. There is also visible white at the top edge of the screen that goes away as the picture fluctuates. There are 5 LED strips. 3- R1/L1 and 2- R2/L2. They were all connected properly. When I tested the voltage, Vout 1 is 61 V and Vout 2 is 91 V. I thought they should be approx 80 and 120 v . I unplugged the TV and the the LED connector and retested. Vout 1 is approx 95 and Vout 2 is approx 140.
Posted by Stl Zou on
  • EllaCharlebois
    EllaCharlebois Dec 02, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Vizio Master
  • 3,588 Answers
Are you measuring LED voltage using frame ground or the plus and minus terminals at the connector
Posted on Nov 24, 2021
  • 3 more comments
  • Stl Zou
    Stl Zou Nov 24, 2021
    I'm measuring black to ground (gray metal case) and red to Vout1 and Vout2. Vout1 measure 61 v and Vout2 measures 91 v when the LED wire harness is connected. There are 10 led's per row. 5 Rows total. 2 rows on Vout1 and 3 rows on Vout2...I believe.
  • Larry Nov 25, 2021
    That's the mistake most make when working on sets with backlight issues. Measuring to ground won't tell much as it's the minus side that's regulated. See what you get measuring from the plus to minus terminals of the LED output, don' t use frame ground. Also check the backlight on terminal of the connector going to the main and make sure the CPU in the main is telling the backlights section of the power board to turn on, should see around 3 volts there.
  • Stl Zou
    Stl Zou Nov 25, 2021
    I'll be honest, not sure where to test. I uploaded an image of my board / connector
  • Larry Nov 26, 2021
    Test between pins 1 and 3 and 5 and 7, test it without an input connected and the voltage should be constant if things are working ok.
  • Stl Zou
    Stl Zou Dec 02, 2021
    Sorry for the delay. Voltage between 1 and 3 was 56.6. Voltage between 5 and 7 was 85.5. Tested DC V with power on, Led connected. I wasn't sure what you meant by test without an input.
1helpful
I have a weird problem: My TV's LED backlight pulses... it is generally off / very dim and periodically the LEDs pulse briefly to a reasonable intensity then fade back to dim every few seconds.
Could be a short in the strips test the strips In each row if you look at the row count the LEDs each require 2.8 dc volts add them up for each row example if you have 9 in the row you will need 25.2 volts dc to power test it .if you look at the right side of the strip you will see 3 dots a plus two minus use center minus as ground and plus for positive . If leds still flicker or dim or some don't light than theres a short within the led strips .
On a Vizio E550i-B2 that has sound but no picture, what are other causes besides the power supply board?
Hello Brian, if you have changed the power supply board and still have no image, then some of the LEDs that are responsible for illuminating the screen are wrong, to solve the problem, you should replace all the LED strips, because if only change the ones that have one or two damaged Leds, the other strips, they could fail you soon and you would have the same problem again
I sent you a video of [ShopJimmy.com] that shows you how to replace the LED strips, in another Vizio TV model of 55 "
I hope you can solve the problem of your TV Vizio
Greetings Franco Dosil
Hola Brian, si has cambiado la placa de la fuente de alimentaci?n y todav?a no tienes imagen, entonces est?n mal algunos de los Leds que se encargan de iluminar la pantalla, para resolver el problema, deber?as reemplazar todas las tiras de Leds, porque si solo cambias las que tengan uno o dos Leds da?ados, las otras tiras, podr?an fallarte pronto y volver?as a tener el mismo problema
Te env?o un v?deo de [ShopJimmy.com] que te muestra como reemplazar las tiras de Leds, en otro modelo de TV Vizio de 55"
Espero puedas resolver el problema de tu TV Vizio
Saludos Franco Dosil
Samsung led tv gets power but see no picture. sometimes have heard sound when toggling through inputs. I replaced the T-con Board and the TV worked fine for a while. Now I'm not sure what to do.
LG LED TV has no picture (black screen) but still has sound - can ...
www.tomsguide.com/answers/id-2660992/led-picture-black-screen-sound-fixed.html
Feb 9, 2017 - My 32' LG LED TV has suddenly lost picture! The sound is alright but the screen is pitch black. ... Then completely black but with audio. ... I'm really hoping if I do the right research Ican fix this tv for my husband. .... Take the screen off hit power and watch LEDs if any don't flash its LEDs if they all flash its ..
1helpful
Vizio flat screen LED TV
http://www.shopjimmy.com/lg-lc550dug-jfr1-led-strips-12-strips.htm
Call these guys. They can assist you. What Vizio is saying is the LED strips are mounted in the LCD panel and cannot be replaced.
1helpful
Black screen, audio, no backlight. What's wrong?
This is most likely a failure of the actual LED strips themselves. They do attach to a board at the edge, it could be the board but you have to order the board and strips as one unit.
http://www.shopjimmy.com/lg-lc420dug-jfr1-led-strips-10-strips-1-board.htm
I replaced both boards on my vizio E420i-AO and I still have nothing when I turn it on. What else can I do ?
Hi Dennis, since you have replaced boards on your TV and still not working.. Check the link below to find additional info on why your TV still doesn't work. Watch the video provided on the link:
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
