Question about Cameras
Stealth cam takes good day ,night are black. Battery are new
Stc pxp24ngk pictures are good except night which are black
Posted by Larry Hayes on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Cameras Master
  • 43,246 Answers
The infra-red source light must be inoperative. Bring it inside in a dark room and move around, look for the red light ring.
Mmmm, no glow IR emitters, clever that you can see them working or not, EXCEPT you can! Use the Selfie camera on your smartphone to look at the front of the stealth camera. IR light sources show as a red dot.
Product description 20 Megapixel Game Camera, 0. 6 Second Trigger Speed and 70 FT No Glo range. 720P HD Video, Video recording 5/15/30 seconds w/ audio. 24 No Glo IR Emitters, Six Quick Set Program Settings, Burst Mode 1-3 images per triggering. 5 -120 Sec recovery time out, Matrix Blur Reduction, 16: 9 Wide image ratio. Includes 8GB SD card, Operates on 8 AA batteries (not included).
Posted on Nov 24, 2021
My stealthcam PX12FX comes up al 8's. Has new batteries and new 4gb sd card
can notify stealth cam 877-­-269-­-8490 ..- this is manual their are no codes or troubleshooting https://www.manualslib.com/manual/837169/Stealth-Cam-Stc-P12.html?page=12#
Nov 05, 2021 • Cameras
Blank pictures
are you on manual or auto? if manual sounds silly but your shutter length is too short/ aperture too small (big number) if auto, do you have flash turned on? if all the above obvious to you... the light sensor on the front might be broke so your cam is picking wrong settings
1helpful
I have a stealth cam STC-1850. Takes good pictures but will not recognize my memory card. Will only record pictures in the internal memory.
What size card are you using? This camera will only take a 2Gb card and may not read anything larger. Try a smaller Gb card
I need the manual for my stc - z31rtl
hi well problem stealth cam get on lock up noreset on box new batter and new card not work need have repair shop ?
8helpful
3answers
On the read out of no of pictures it shows loc and can not get it cleared
I have a Stealth Cam Skout 7. The screen displays Loc or Lock. To fix this.. On the side of your SD card there should be a little rectangle that will slide back and forth. Slide it the opposite way to unlock it.
2answers
Stealth cam digital game camera not taking night pictures
i opened up the unit and found the wire from the cover had became loose from its soldered point, where does it go so i can resolder it.
Open Questions:
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
