Question about Samsung Cell Phones
How Can I pair my Samsung Gear3 watch to my Infinix phone?
Whenever I attempt to pair my Samsung Gear3 watch to my Infinix phone, it gets stuck at finish pairing.
Posted by Toonday on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Samsung Master
  • 41,628 Answers
Pairing Bluetooth Devices
Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever. (Infinix Phone)
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. (Samsung Gear 3) On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by ADMIN... on Nov 19, 2016
Videos on how to Pair the Gear3 Watch here
https://www.google.com/search?q=samsung+gear+3+watch+pairing+with+phone
Posted on Nov 23, 2021
How do I fix my infinix phone camera
How to fix Infinix camera not working-Carlcare
https://www.carlcare.com > tips-detail > fix-infinix-cam...
Aug. 9, 2020 - The issue of your Infinix smartphone camera not working may be due to a software or hardware problem. Now if it's a software problem, there are ...
and lots of videos. This appears to be a known problem
https://www.google.com/search?q=fix+my+infinix+phone+camera
Jun 08, 2021 • Cell Phones
Pairing my samsung galaxy grand prime phone with my 2014 honda cr-v vehicle
the password or pin is likely the password or pin to open the phone.
1helpful
How to pair samsung gear 2 with samsung mega??
Your gear 2 may not be compatible because pairing will require the samsung store to download the gear manager, it may be a very nice watch, but you should've check for compatability, but if you just want it to work, just find a store like best buy that has a samsung S5 or note 3 as a working show model(one that can be accessed by customer ), pair it, and let the phone install the updates, that's what one guy did after a unboxing video on youtube .
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Mine is a 1997 FZR 1000. I discovered that whenever i move from gear 1 to gear2 and i rev a little, it will make a loud noise like when you are on neutral and you rev it high. At that point what i do...
Possibly a worn selector or in the worst case teeth missing on a cog or two.
I would get it fixed before it lets you down and needs a very deep pocket to fix.
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
12helpful
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
shizznat
Level 1 Expert
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
