Question about Samsung Televison & Video
Samsung 70 inch tv! Un7069nu00fxza
I'm having an issue with my 70 inch Samsung tv. Un70nu6900fxza Version ya02. I replaced the power supply board but when I turn it on it still cycles and shuts off a couple times. I'll repeat this process with the ribbon cables unplugged, then once I get the back lights to stay on I will plug both of the ribbon cables back into the main board. Then I will get picture. The tv will act normally and function well until I turn the tv off. Then I have to restart the whole process over again.
Posted by Kyle Cota on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Samsung Master
  • 3,598 Answers
You said you replaced the power board, what was the original issue with your TV?
Posted on Nov 24, 2021
  • 2 more comments
  • Kyle Cota
    Kyle Cota Nov 24, 2021
    I originally thought that it was the issue based on what little research is available. But with replacing the power board I am still having the same issues.
  • Larry Nov 24, 2021
    A TV with your issues is easy to troubleshoot one nice thing about a power board is it can be tested very easily. It needs 5 volt to light the standby lamp, if that's not there replace the power board, when the power button is pushed you should see 3.3 volts at the ps_on terminal of the plug going to the main board, if you don't see that the main board is bad, if you see it the other voltages should be present, if they aren't the power board is bad. Where did you get the replacement power board. If it came from ebay it's possible you received a replacement that's defective. These tests need to be done when the set is not working. The only thing that doesn't make sense is the ribbon connectors shouldn't make the set come on. You can test the backlight section by unhooking the cable going to the main board and on samsung sets the backlights should come on if they work ok
  • Kyle Cota
    Yes backlights stay on when you unplug the cable that runs between the main board and power supply board. I bought the replacement board from ShopJimmy.com.
    That's about the best place to buy a board as they test them before they package them and ship.
2answers
How to fix Samsung TV Black screen?
It is problem with the power supply for your TV and the power supply needs to be replaced. If your TV still is not working after the power supplies have been replaced then you should just buy a new TV that would be better just to buy another TV than to try and fix the current one that you have.
3answers
Samsung backlight on and off w/ no picture?
Fault with the main power supply [SMPS] board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
I have a 4k, 50in. LED Onn tv, I need to order a power supply, who can you refer me to, so That I may order the part. Thanks, Joey Bush
Shop Jimmy. Tell him we sent you :>)
https://www.shopjimmy.com/
OR
brand-ONN - LCD / LED TV REPLACEMENT PARTS ...
moretvparts.com > ... > onn
ONN ONA65UB19E07 TV LED STRIP M08-TP65030-0601N-4270A. $10.00 ... ONN ONA65UB19E07 TV POWER SUPPLY BOARD PW.168W2.802 / ...
onn tv 50" ' eBay
www.ebay.ca > sch
ONN ONA50UB19E05 TV Repair Parts Kit -Version 3 (SEE NOTE). New (Other). C $65.80 ... ONN 50 Inch Roku 100012585 Tv Stand With 2 Screws ... New Onn 100007147-H / JVC LT-50MAW595 Power Supply (TV5006-ZC02-02) E021M289-T1. Brand New ... Onn ONC50UB18C05 4K LED TV EACDJ6E10 T-Con Board.
Television Replacement Parts: Electronics - Amazon.com
www.amazon.com > Television-Replacement-Parts
Results 1 - 24 of 3000+ - Online shopping for Television Replacement Parts from a great ... LB70006 Replacement LED Backlight Strips (12) for Vizio E70-E3 ... BN44-00808D Power Supply Board Compatible for Samsung ... Stream 4K Video ..
My Sharp Aquos 70 inch tv will not turn on. The little chevron shaped light on the front bottom center of the tv keeps flashing 2 slow blinks followed by 2 fast blinks?
Thank you Much. I called SHARP for service code reading with absolutely NO help. Was told to call a service tech. I can fix this and at least know what to look for.
1helpful
2answers
I have a Samsung UN60H6203AFXZA (Version GH02) TV that won't power on and the red standby light is not lit.
Your issues come from the hot side of the power supply. You can replace the power supply and it should work again or if your capable of repairing it yourself you can do that for a few bucks. below is a link for a new PS, also shopjimmy.com would have one
Samsung Power Supply Board BN44 00772A for UN60H6203AFXZA eBay
1helpful
Sharp 70 inch tv flickering issue
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2answers
42inch samsung ln40b550 turn on my television it flickers wildly
This is a common Power Supply / Backlight Inverter Board issue. If you open up your TV you will see a long white board that is on the right side of your TV. You have to replace that board to get this issue fixed. You can find the board here BN44 00264B Samsung Power Supply Backlight Inverter
7helpful
2answers
HP-T4254 samsung TV turns itself off and on constantly
Try this step before purchasing power supply. I have serviced this tv before. Lay it flat plug it in and it should turn on,but once you sit it up straight it will turn off. I think there are faulty fairchild mosfet transistors or a firmware issue. I put a 1 inch thick book under the stand so it tilts up or down. I have not had a call from any customer since.
3helpful
4answers
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
6helpful
2answers
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
