Question about Samsung Televison & Video
Samsung ln46d630m3f sound no picture
I held a flashlight by it and can see images on the LCD screen. I am trying to isolate between the power supply board and the inverter board. The power supply board says CNI801 high lead output rating is 273VAC and the low lead ratin is 193VDC. Both are reading ~10V AC. I am not getting any high voltage out on the inverter board.
Posted by Pat Hamrock on
  • CarolBow
    CarolBow Nov 27, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Samsung Master
  • 3,588 Answers
What's the part number of the power board? Not sure where it would have said that connector 801 has 273 VAC as it would be impossible to get that voltage from a modern power supply board, max would be 120 volts ac times 1.4 or about 165 vac
Posted on Nov 24, 2021
  • 7 more comments
  • Pat Hamrock
    Pat Hamrock Nov 24, 2021
    Power supply board is BN44-0463A Rev 1.2. The voltage I referenced is the voltage rating stamped on the board, may not be the actual expected output voltage. Pictures attached.
  • Larry Nov 25, 2021
    I pulled up service info on the power board, I didn't realize this set had CCFL lamps, thought it was LED, when you test the output voltage that is supposed to be 273 VAC what are you using for a ground?
  • Pat Hamrock
    Pat Hamrock Nov 25, 2021
    I’m using the ground pin on the same connector.
  • Pat Hamrock
    It is pin 8 in the photo. I could not find the service online.
  • Pat Hamrock
    And…thank you for the responses!
  • Larry Nov 26, 2021
    Your welcome! if you look at the board you will see a white line across the connector, the top part is the cold and the bottom is the hot side of the power board. When testing the cold side you use the frame or the ground pin to test but if testing the hot side you can't use the frame as the ground as the PWM section is isolated from the frame ground, you need to use the minus side of one of the large capacitors. A word of caution be very careful when doing that test as the hot side of those caps will have around 380 VDC and that really hurts if you get across it and it can be really dangerous. I have a feeling your power board is working ok and you have bad CCFL, most likely one is bad and drawing to much current and the inverter board is going into over current protection, another thing to check is the ballasts on the inverter board, see if any have got hot. One other thing, are the lowerpower supply voltages ok
  • Pat Hamrock
    Pat Hamrock Nov 26, 2021
    Thanks for the follow up. I’ll check those items this morning.
  • Pat Hamrock
    We’ll, while checking voltage w/ multimeter I had an arc on a cap lead to the probe and now appears power board is out completely. Set will not power on anymore.
    I appreciate your input, but thinking it’s time to give up on this one.
  • Larry Nov 27, 2021
    It's really easy to get between the plus and minus on the large caps as the leads are close together, I've had it happen several times when I wasn't careful enough, chances are it took out the fuse and rectifier diodes, I agree unfortunately it may be time for a new TV
Chris Howard
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Your LCD backlight capacitor is bad somebody will have to locate it and put a new one in
Posted on Nov 26, 2021
I have a samsung tv un46eh500 with sound and a dark image. Should i replace t-con board?
Hi Bill, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
3answers
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
1helpful
3answers
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
My samsung tv la27t51b has no picture and only sound on dvd
You can go to near samsung service centre for best help.
thanks..
My Pahe : onsite training
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
2answers
No sound or picture HL-R5067w
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
