Question about The Computers & Internet
I have gun safe 6741 bought from costco. I hear a beep. I have changed the poles and I am no longer able to operate it. the yellow light comes on and it beeps 4 times. the keyboard does not respond well and the mechanism does not operate. What can I do? is my electronic card defective? how can i get a new card?
Posted by Daniel Bolduc on
  • 1 more comment
  • Larry Ng
    Larry Ng Nov 25, 2021
    RTM YET, READ THE MANUAL
    CALL THEM YET, NO.
    THE BATTERY IS DEAD.
    THE MANUAL TELLS YOU WHAT TO DO.
    NO BRAND TOLD.
    I guess you threw away all papers important day1 new on this safe for sure the support page?
    and lost the special key to this safe too> oops?
    google (amazing no?) told me made by this Company, Sargent
    [email protected]
    page 1 step, fig. C = kEY)
    Step 3: (Refer to Figure C) Insert change key into key hole on the lock’s cover. Change key must be completely inserted
    https://sargentandgreenleaf.com/product/...
    its all there to read or call or email them click what is there.
    and is not a computer at all.
  • Larry Ng
    this safe I guess has the electronic model, dial.
    so you will need to find how which one it is.
    here
    https://sargentandgreenleaf.com/sg-produ...
    or call them and they will walk you through this.
    the mech.version can not beep. so is electronic and has dead or weak battery.
  • Anonymous Nov 25, 2021
    costco does not make safes, at all
    the sell them
    and some put there logo on it safe but that does not make it their safe. (just the silly sticker)
    the maker of this safe is told above so ask them, and them only
    do not make rash hacks or the like or MAKE IT WORSE YOU WILL.
    if it is electronic dial
    safe
    next time use lithium battery and it migth last 5+ years, or 5 times alkaline.
    even sold at walmart, for sure.
    case in point (guessing AA cells)
    worth every penny, and less grief.
    https://www.walmart.com/ip/Energizer-Ult...
    I do not have your battery spec but most times it is AA or AAA or 9v battery and they sell the better battery
    like above.
ADMIN Canada
    Top Expert:
  • The Master
  • 41,552 Answers
I am sure I answered this already. Open it with a rare earth puck magnet and change the batteries. Clean the contact on the keypad with Switch Cleaner at the same time.
https://www.firstalertstore.com/store/products/Protector-by-First-Alert-Fire-Resistant-Executive-Gun-Digital-Safe-6741DF.htm
Open with magnet
https://www.youtube.com/watch?v=TBhfnIu9lTw
Posted on Nov 25, 2021
ray gallant
    Top Expert:
  • The Master
  • 73,782 Answers
Check with Costco
Posted on Nov 23, 2021
How do I reset the code on my garrison electronic safe EA20 safe
To change the code
A. With door open, locate the red button on the back of door near hinge and press.
you will hear 2 beeps and yellow light on (10 seconds)
B. Input a new code of 3 to 8 digits, then press "B" button.
The storage of the new code will be confirmed by two beeps
tip
PS3 Safe Mode
Sony PS3 Safe Mode
If you choose to perform one of the Safe Mode options, please back up your data before attempting to enter safe mode (when possible).
Safe mode is a feature for starting the PS3 system with the "minimum required functionality" if the system is no longer able to start up normally due to an action that was taken.
In Safe Mode, you will have the following options:
  1. Restart System - Ends safe mode and starts up the PlayStation 3 normally.
  2. Restore Default Settings - Performs the same operations as [Restore Default Settings] on the XMB, and also deletes PlayStation®Network account information from the system.
  3. Restore File System - Attempts to repair all areas on the hard disk drive where files can be saved. Corrupted data may be erased if it cannot be recovered.
  4. Rebuild Database - Deletes messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information.
    This operation may take a long time depending on the type and number of data items.
  5. Restore PS3 System - IMPORTANT: All data will be lost by performing this step.
    This will reformat the hard drive on the PlayStation 3, deleting all data and restoring it to as if it just came out of the box. This is the same as [Restore PS3 system] on the XMB.
  6. System Update - Updates the PS3 system software. This can only be done with an update file already saved on an external storage media.
To activate Safe Mode, follow these steps:
Step 1: Turn off the PlayStation 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PlayStation 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
4. Connect a USB cable to the controller and the PlayStation 3 and press the PS button to enter Safe Mode.
5. Then you will see the Safe Mode menu.
Sony recommends performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
I hope that helps.
I have a first alert safe bought from costco about 7 years ago. It is a model 7334DFB. It does not want to accept my 6 digit passcode and comes up with 3 beeps. How do I get back into my safe?
hi thomas
after reading your question i found this site help it helps
http://manualzz.com/doc/3151997/first-alert-19-cu.-ft.-gun-safe--user-s-manual
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
How do you change the code on a Legacy Safe?
Make sure you do this with the door OPEN.
Make sure that you have a fresh battery in place.
Hold down the 0 until you hear a beep twice
Make sure that you have written down your new combination before you enter it, then enter your old combination. Wait for the two beeps.
Now enter your new combination and wait for the two beeps.
Enter your new combination again, waiting for the two beeps.
Wait for 15 seconds, then enter your combination; you should now be able to turn the handle.
1helpful
2answers
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
2helpful
I bought a house and have a hardline safe is there a way to reset the safe password. .
User override key to open safe.
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
1helpful
HOW DO i CHANGE THE CODE ON MY EA25 SAFE?
Hi
To change the code open the safe, press the red button and the yellow light goes on, indicating that enter the state to change the code. Input the new code (1 to 8bits), then press ‘B’ or ‘A’ button, it will be confirmed by two beeps, indicating that the new code have been accepted and stored. However, if the yellow flash with the buzzer beeps three times means the new code is invalid and should operate again.
Hope this helps
Thanks
Daniel
I bought an electric power washer from Costco
Look for the your washer on ebay. Often you find the units and on same page it is very common to find parts for the unit! And on ebay you can shop for and get all sorts of electronic and plumbing adapters that are virtually impossible to get - they may come from China and take a few weeks to get to you but they are inexpensive and they work and are guaranteed! eBayeBay
157helpful
3answers
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
