Ovens Logo
P
Pearl Fleischmann Posted on Nov 22, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore gas built in oven has f10 on panel - Kenmore Ovens
Level 3:
  • Kenmore Master 19,187 Answers
  • Posted on Nov 22, 2021
Kenmore Master
Level 3:
Answers
19187
Questions
0
Helped
4339506
Points
82259
1helpful
2answers
Kenmore Oven 790.94173310 Giving F10 Error
If it is giving an overheat alarm, I would have replaced the sensor anyway. If you have been using the self cleaning feature of the oven, it may be that, that burned the board.
https://www.google.com/search?q=kenmore+convection+oven+f10+error
Kenmore gas oven built in. It has F10 Error Code on the control panel display.
Question edited for clarity.
You need a service call. It's dangerous.
The F10 code on a Kenmore oven means that the oven is overheating - the oven is detecting a temperature far over the safe range of operation. Most models also start beeping when this happens since it can be a safety concern.Apr. 14, 2020
How to Troubleshoot Error F10 on a Kenmore Stove ' Hunker
https://www.hunker.com > ... > Other Home Appliances
About featured snippets
1helpful
Kenmore stove
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel.
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
What is F10 error code
http://www.applianceblog.com/mainforums/sears-kenmore/11065-kenmore-range-f10-error.html
Hi this website above directly addresses your issue.
F10, is an Over temperature, usually a bad thermistor or similar, as related see above post. For ID & repair parts and all.
2helpful
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
4helpful
Kenmore Gas Oven F10
check the temperature sensor. TURN POWER OFF!If you open the panel where the controls are located you will see a connector that has about 10 wires on it. 2 of these wires will be violet. Pull off the connector and check the resistance between the 2 violet wires. It should be around 1000 Ohms.
If not, it is bad. part# for the Kenmore Model 790 is 316217001 - cost is about $25.00
3helpful
2answers
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
