Question about Daewoo Washing Machines
Where I could find the Daewoo Front Load Washer 7kg DWD-N1011 DWD-N1011 Circuit, seems an iC is not working and I have repaired it few times. Now I need the full circuit in order to replace it, any thoughts where I could order it?
Posted by Sachith Hirantha... on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Daewoo Master
  • 41,747 Answers
ray gallant
    Top Expert:
  • Daewoo Master
  • 73,787 Answers
TRY A DEAWOO DEALER
Posted on Nov 24, 2021
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
2answers
How to clear impellor
Top unscrews, impellor lifts off. Any tangled items can be pulled clear
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
5helpful
I have a daewoo 7kg direct drive washing machine DWD-14ODS i put a load in it got a couple ov minutes into the cycle then started bleeping and is displaying LE on the screen there is some water in the...
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
7helpful
5helpful
2answers
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
2answers
Error code E8
Most likely a control or motor issue. Probably should call service.
Washing Machines Logo
Top Daewoo Washing Machines Experts
Paul Bade
Fahr Quad
Dennis
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
