Question about Thermostats Heating & Cooling
Main Flame will not turn on.
I have a Gas fireplace with a Sit V/v that has been running fine for many years, however, this year not so good. The pilot light is one I disconnect the Thermostat and joined the Black and White wires together still nothing, and then with the pilot on tested the Thermopile and got 0.4333 Volts. I also removed the Thermocouple from the main V/v it tested to 0.028 volts. I also disconnected the Thermostats connecting to the TP/TH and TH and placed a jumper on them still the Main gas flame stays off. Any thoughts on what else to try? Is there a a way to bypass the Thermocouple? Thanks you for any help. I hate to buy a new V/v and find out I missed something I should have checked.
Posted by William Bleasdale on
Paul Carew
  • 3,696 Answers
You cannot bypass thermocouple it a saftey device ,
Posted on Nov 21, 2021
Testimonial: "What can I say except that he was more than I had hoped for. Thank You"
  • 4 more comments
  • William Bleasdale
    William Bleasdale Nov 22, 2021
    Thanks for getting back to me I realize it's a safety device I want to bye pass it just prove if it's good or bad.
  • Paul Carew Nov 22, 2021
    no you cannot do that .only way is a tester that goes inlline with the thermocouple and gives areading on a muit meter .Just change thermocouple it don't hold its the power unit then you will have to chang the valve
  • William Bleasdale
    William Bleasdale Nov 25, 2021
    Thank you once again, yesterday I removed the gas V/v and tested the thermocouple using a gas light allowing it to reach a glowing red. It showed 433 millivolts which tells me it's fine, however, I change it out, At the same time I did the same thing with the thermopile and it heated to 900 millivolts which once again is in range, however, I replaced it with anew one. The pilot light works great heating up both thermo's but still no main startup. I don't think there;s anything to do but change out the mail gas V/v. All the wiring was checked from the thermostat to the fireplace and found to be good. I also disconnected the thermostat and went direct (jumper). But nothing. Any thoughts?
  • Anonymous Nov 25, 2021
    No you have proved the valve is not working .You have done what I would have done . You coved all possiblites Nothing I can think of .
  • William Bleasdale
    Thank you for your time It's nice to know there's still people out there that care. I'm a marine engineer or was now retired, but still find time to teach at a small marine college when they need someone.
    Stay safe and like I said thank you very much for you input.
    Bill
  • Paul Carew Nov 26, 2021
    Thanks Bill Old school as they say now .
My fireplace doesn't light right away, then it shuts off after a few minutes.
sounds to me like your thermocouple is loose just go to where it connects to the gas valve and tighten it most times this happens after it has been replaced, because temperature changes loosen them also make sure the pilot flame is directly on the thermocouple , sometimes dust gets in to the pilot and changes direction of the flame making it "grade the thermocouple, with the main burner on the air flow sometimes "moves the flame and the thermocouple thinks it went out and shuts down the main burner. extinguish the pilot, either blow it out with canned air, or use a q tip to reach down and dust it out then re light. should be good
tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 • Heating & Cooling
Gas fireplace will not light up
If it has a pilot light, (website says it does) I suspect its the thermocouple. These are easy to change yourself and cheap, you can buy a universal thermocouple and it will be cheaper than a Napolean one. The end of the thermocouple is a fat copper pin that sits poking into a small pilot flame. The heat of the flame on the copper tells the system that the gas is burning ok so it allows more gas through. But after a few years the copper end gets covered in black charring and this slightly insulates it from the heat, so it signals to turn off the gas.
GAS FIREPLACE SOMETIMES TURNS ON AND SOMETIMES NOT. ALSO, IT CAN BE ON AND THEN THE FLAME GOES OUT BUT A FEW MINUTES LATER COMES ON. SUGGESTIONS?
This is a typical situation for a warn Powerpile generator. Your fireplace works by this generator generating heat from your pilot flame and converting it to less than 3/4 of a volt or 750mv. Your gas valve will eat up half of this electricity when running. So when you Powerpile gets warn it might only generate 400mv and when the gas valve turns on will bring it down below 200mv. This will start to drop once the main burner turns on and once below 150mv is no longer able to power the gas valve resulting in the main flame to go out. Minutes later the generator will build its power up again and repeat the cycle. The generator looks a little thicker than a crayon and has a red and white wire coming off it. They are easy to change but the tight spaces on a fireplace can make it very difficult.
1helpful
4answers
My gas log fireplace runs for 2 to 6 minutes and then quits on its own. It is 10 years old. Any suggestions?
Look for a flame sensor, It is a wire that is has to sit in the path of the flame. IT is gets dirty and can cause this. You can clean it with scotch brite pads
Feb 28, 2013 • Home
2answers
My fireplace wont stay lit with the glass on the min i take the glass off it will stay lit i have a good vent and it is propain could it be that there ant enough gas presure it is a heat n glo 6000 the...
The reason this is happening is that the overload switch, which is part of the safety features has gone bad. That's why the burner will only light with the glass off. The orange color of the flame from the pilot flame is normal for propane.
Unfortunately, this is not a DIY fix. If you can find a qualified service technician, that's the best way to go. As, Heat-n-Glow fireplaces are a basic, builder box line. And as such, have some quirks that other, more expensive gas fireplaces don't have.
Hope this helps solve your problem.
3helpful
2answers
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
3helpful
Rheem gas water heater it won't stay lit...will lite up and go off after 20 seconds or so. If I leave it sit for 20 minutes the exhaust fans blows but no flame and I have to turn off gas and refire up to...
For the main gas valve to come on several conditions need to be met.
The system must detect a pilot light prior to turning on the main gas valve for systems with a standing pilot light (not sure what your system has) and on systems with auto igniters (spark or ceramic heat glo) the control board must detect a flame present at the main burner a few seconds after the main gas valve turns on.
The other condition that must be met on systems with power exhaust systems is a vacuum/pressure diaghram switch must be made and stay made telling control circuits that vacuum/pressure is present = power exhaust fan is on and working.
From your description it sounds as if you may have a dirty/failing flame detector (thermocouple). Remove it and give it a good scrubbing with a scotch brite pad etc. cleaning off any carbon or corrosion/gunk re-install and try it out, or simply spend $15.00 or so and install a new one to be sure. The thermocouple is the metal thin tube that protrudes into the pilot and/or main burner flame and is connected to the main gas valve by a thin capilliary tube.
To check the vacuum swich on the blower a multi meter across the switch terminals looking for a steady "state change" as the blower runs/stops will work.
9helpful
2answers
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
My gas fireplace turns on for a minute or so. then the flames turn blue as if lacking oxygen, then go out completely.
Blue is a good flame.. Yellow, lazzzy flame is lack of oxygen. When the main flame comes on, it may be pulling the pilot flame away from the thermocouple..
Heating & Cooling Logo
Top Thermostats Heating & Cooling Experts
Paul Carew
john h
ADMIN Canada
ADMIN Canada
Are you a Thermostats Heating and Cooling Expert? Answer questions, earn points and help others
