Question about Samsung Washing Machines
I cleaned out my Samsung front loader pump filter, but now no water comes into the washer and there is no error code. Please help!
I forgot to drain it before I unscrewed the filter, so quite a bit of water ran out. Could I have shorted something out?
Posted by Jo Lynn Love on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Samsung Master
  • 41,747 Answers
Unlikely you shorted something as the area is protected from water. Try disconnecting from the mains supply for 30 minutes. You can als Google
make model reset
sometimes there is a button push combination to reset the logic boards.
Posted on Nov 21, 2021
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
1helpful
Error message of f02 on Kenmore HE3 front loader washer at end of cycle
The F2 error code indicates that the washer spent too long in the drain cycle,that typically is due to the drain pump filter being clogged. It's fairly easy to clean that filter by removing the lower panel and unscrewing the filter on the lower right side .Be prepared for some (perhaps a lot) of water to come out when that filter is unscrewed so have some towels or a couple plastic tubs to catch the water that comes out DO NOT completly remove that screen until all the water has come out or be prepared to get very wet by pulling it out without first catching the water
Hope this helps and if it does please give me 4 thumbs up
Gene
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
2helpful
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
4helpful
Wont drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For most front loaders:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
You could also check the exit hose of the washer for blocks. Next snake out your wall drain, it helps.
3helpful
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
1helpful
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
3helpful
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Washing Machines Logo
Top Samsung Washing Machines Experts
Joaquim Martins
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
