Question about Alcatel Cell Phones
How do I bypass emergency calls on a lock screen on a Alcatel Insite
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Alcatel Master
  • 41,627 Answers
Question edited, the phone is an Alcatel Insite, not an 'inside'.
You can't bypass. If the company locked you out they did it for a reason. If you don't have the consumer set lock code, you can only fix that by doing a Hard Reset and scrub it clean. If you are trying to get into your partners phone, that doesn't go down too well :>D
If the phone is stolen, reported stolen, of if 4 attempts have been made to open it, the phone will be PUK Locked and only the telco can provide to code for that.
https://us.alcatelmobile.com/alcatel-insight/
Posted on Nov 21, 2021
2answers
How to bypass pattern lock screen on a ZTE
If you own the phone. You could do a master reset.
How to bypass the google/frp lock on a alcatel gophone model 5044r
There are a couple of processes to bypass the google FRP of an Alcatel Go phone device. Here, I am providing the without OTG process.
  • FRP Bypass Download and send it to a portable mini drive
  • When you asked for verification, connect your device to the portable mini drive with the help of USB OTG cable.
  • Install the FRP bypass tool
  • Open the tool
  • factory reset your device from the backup and reset function
  • 0helpful
    Bypass emergency call screen of Alcatel A462c?
    You need to unlock the screen. Look for the picture of the padlock and tap it. It will then show what type of screen lock you have enabled, ie swipe, pattern, pin or password.
    1helpful
    Razr V: how do i clear the emergency call screen? just appeared, no way to delete or bypass? thanks.
    Wayne
    You have to have a SIM in the phone if you don't have one. Otherwise Emergency calls only. If you do have a SIM but you are getting that it means the Sim is not detected or is inactive or you've pressed emergency call and the phone is locked. You should have a back button to dismiss emergency dialer and enter pin or pass code.
    Mark
    Motorola Support
    "emergency calls only" will occassionally display on my alcatel cell phone.At that time I can't make other calls. What is wrong?
    Emergency calls only is a symptom where a cellphone loses its registration to a valid network operator. It usually happens to me when I am in another country and the cellphone cannot locate valid operators. Looks like some telcos choose particular network partners. What I do is choose the network operator manually in the phone's setting.
    If you are in your home country and this happens, it only tells you that you are out of coverage area and the phone is losing connection to your network operator. Maybe you are inside a building with thick walls which cause poor reception. You may try choosng an area where the symptom goes out.
    1helpful
    ALCATEL ONE TOUCH EMERGENCY CALLS ONLY
    There are two possibilities to your phone shown Emergency calls only.
    1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
    2.Your mobile is locked to particular network provider.
    If your problem persists after switch on your mobile phone,definitely your mobile phone restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit ClassicUnlocking.com I hope it will be very useful to you.
    Alcatel vodafone sim lock, sos calls only
    Sim Lock also known as Network lock,You need to Unlock Your Alcatel Phone from network lock to use with other GSM Network Sim card.What is Mobile Phone model?It locked which country,Network?
    Buy the Unlock code from the site Onlinegsmunlock.com and Unlock it from network lock.SOS call means Emergency calls ...You can unlock it ,use any GSM Network Sim card...
    Feb 06, 2012 • Cell Phones
    Cell Phones Logo
    Top Alcatel Cell Phones Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Vernon Taylor
    Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
