Question about GE Washing Machines
How to unlock my GE front load washer
It's been lock since last Sunday. I'm afraid the many options we've tried has added more problems
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry Ng
  • GE Master
  • 6,112 Answers
Post to washing machines, it is CLOTHES or DISH washer.
top posting to GE computer repair help,
and
here we click on browse
https://www.fixya.com/support/forum
then i look for the word washer,
and click DISH or click Cloths.
post there not here ever for that.
or RTM read the manual and get it at GE.com? for free
here is CLOTHes
https://www.fixya.com/troubleshoot/ge/washing_machines
locked means door locked???????????????????????????????
no model told on the rear is a tag and the model is there vast exist. for decades
no 2 the same.
my wild guess is the washer failed mid cycle and door locked to be safe.
why not turn the dial to spin dry and get it to finish that cycle
and now door opens
if spin fails , then post in the correct forum that FACT. (will not spin cycle dry)
or call for service, YP.com in you town.
Posted on Nov 20, 2021
2answers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
2helpful
My washer has a red lock displayed on the screen and it won't do anything.
the control lock function is activated...hold the options and select buttons together for 15-20 seconds(won't take this long) and it should unlock your controls...any problems, let me know
Bruce Denton
GE WBVH6240FWW front load washer is locked at the keypad and wont unlock. tried to hold the unlock button in for more than 3 seconds and still wont unlock. even tried turning power off and unplugging the...
my machine is doing the same exact thing (WBVH5100HWW). Day 3 of not being able to unlock it. It just "clicks" like it's in lock mode. I even unplugged it, no luck. Even when you turn the machine off, the motor running, but nothing inside the barrel is happening. It just makes that annoying "beep" noise stating that it's locked. I've had nothing but problems with this machine and it's just barely over a year old. I just found out that there is now a recall due to fire hazzard.... so, FYI.... here's the info:
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10259.html
if anyone has any suggestions, I am ALL ears. So frustrating. (thanks).
1helpful
My ge front load washer door has locked and won't unlock.
The unit will not unlock if water is present. Look for a blocked pump problem
1helpful
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
5helpful
GE Front load washer - cannot unlock door
manual lock release is located inside front panel. remove lower kick panel and reach up on latch side and feel for plastic tab hanging from lock asm. pull down.
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Open Questions:
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
