Question about GE Washing Machines
Agitator on GE topload dual action moving in one direction
Posted by Douglas on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Curt Mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 157 Answers
The Agitator In your washer has two parts. The bottom half will move back and forth. The top half (spindle) will move in one direction (clockwise). Most of the scrubbing or washing is done by the bottom half of the agitator. The spindle is responsible for pulling the clothes down from the center and sending them to the bottom where they will be scrubbed. As the clothes circulate, they will all be washed.
Posted on Nov 24, 2021
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Hw to get fabric unstuck from bottom of agitator on a GE Gtwn2800Doww topload washer
Some agitators at the top have a plastic lid that has a bolt under it holding the agitator in washer. Take the bolt out and agitator should come out of washer.
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Kenmore 92587400... The dual action or top portion is not spinning
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92587400
    I assume that you mean that the top agitator is not.
    See the section of the Sears site for Agitator, Basket and Tub.
    You'll see an item #5 "Clutch, Agitator". These are basically used to allow the top agitator to move only one way. If they are worn (which happens since they are plastic parts) the top agitator may not move either way.
    There is also a part #6 "Agitator Auger" that screws into the main agitator shaft from the transmission. If this is loose, the top agitator may not move either.
    Both of these are easy to check and repair.
    1helpful
    Machine does not agitate, will spin and rinse including.
    Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
    I need to remove GE topload washer agitator
    Pull up hard on the agitator. It will come up.
    GE topload washer Agitator
    theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
    Open Questions:
    Washing Machines Logo
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Gerry Harvey
    Gerry Harvey
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
