Question about Whirlpool Washing Machines
Whirlpool cabrio will not spin
I just replaced the lid lock switch, drive gear, drive belt, and main board. Now what?
Posted by Rose on
Molmul Banga Banga
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
If your Whirlpool Washer is not spinning the problem is almost always the lid switch. If the lid switch is bad you will not hear the motor running when in spin. To check the lid, first unplug the washer.
Posted on Nov 25, 2021
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Washer won't agitate or spin
My whirlpool duet stacking washer wont spin or drain. i tried to do it manually as described in my owners manual with no luck
How to replace a bad lid switch to a washermachine
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Whirlpool cabrio washer no longer spins
Most likely control board. On a cabrio main power controls everything. If it agitate and drains and does not spin that's what it will be especially if there are no codes. Only other thing that could prevent spin, is a bad lid lock. But if there are no codes it a board.
Wtw5500x whirlpool cabrio can i bypass lid lock switch
No its linked to the main board. Well if you were an Electrical PLC engineer, maybe
Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
3helpful
2answers
Washer does not spin
Hi, There are several causes for this problem. Check these.
  • No spin at all: the lid switch is fried. You test it with your meter.                                  There will be a motor which spins the washing machine's drum.                                              If you don't hear the motor running, then its the lid switch which would have been broken and needs replacing. A bad lid switch wil interrupt the spin cycle.
  • In the Whirlpool washers, a common problem is that the lid plunger stops making contact with the lid switch. Use a pen to manually press the lid switch actuator (with the lid up, duh). If the washer spins...well, you know the rest.
  • Older (belt-drive) Whirlpool: the spin solenoid is burned out or has cut wires. Ohm out that solenoid (20-30 ohms) and test with a test cord. Make sure the wires are intact by giving them a little tug. If this is OK, you may need to adjust/replace the basket drive.
  • Timer is fried. On older timers, it's sometimes possible to run an external jumper to replace the bad internal contacts. Usually, however, the entire timer must be replaced. The only way to confirm is to use your meter and wiring diagram.
These are the causes that have to be inspected. You can also visit this site www.whirlpool.com/custserv/index.jsp
Hope my info solves your problem, Thanx for using fixya, Good luck.
Open Questions:
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
