Question about Cameras
How to remove ignition switch 2000 Saturn LSeries
Locked in off Position
Posted by Dale Humble on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
john h
    Top Expert:
  • Cameras Master
  • 25,703 Answers
Jiggle steering wheel back and forth and try turning key ---or key worn down and not recognized in cylinder https://www.youtube.com/watch?v=4Q66GETmzEY
Posted on Nov 19, 2021
Location of fuse for trunk release 2000 Saturn LS1
page 5-84 of your owners manual is for your fuses and relays if dont have one this link is your manual https://my.gm.com/content/dam/gmownercenter/gmna/dynamic/manuals/2005/saturn/lseries/2005_saturn_l-series_owners.pdf
2answers
Why is my 2000 Saturn LSeries making a ticking noise after oil and filter change
Next time you changer oil fill oil filter first to it all the air out filter some time in older car the oil pump need to be prime .
2000 saturn sedan horn will honk when key is removed from ignition. When horn relay is removed, headlights stay on. Also intermittent issues with car starting up, will turn over but not start, also key...
Possible bad ignition switch. Security is partly ignition as well as headlights r part of security all tied to ignition.
Should be looked at by certified mechanic. Not hard, but not easy fix either.
MY IGNITION CYLINDER ON MY 2000 SATURN LW1 LOCKED UP AND HAD TO PURCHASE A NEW ONE. HOW DO YOU GET THE OLD CYLINDER OUT
You will have to remove all the cowlings from the steering column to access the ignition lock and switch. With the correct key inserted and selected to, probably, the ACC position, you should be able to push on either a pin or a tongue that protrudes from the switch into the housing and the pull the whole lock/switch mechanism out.
1helpful
Locked ignition. Can't get car out of park or turn ignition switch. Ignition is locked up.
you will most likely have to replace key cylinder. remove cowl around steering column, upper & lower, remove plastic cyl around key, you will need a paper clip to remove key cyl. small hole near back of key cyl, install paper clip end pushing down turn key cyl, to run position, jiggle key cyl to remove. auto parts store should have replacement. good luck
My diagnostic code for a problem wiith my 2004 Saturn LSeries was PO742 Transmission Converter Stuck, will this be a costly repair? Also my brake switch needs replaced, will that break my bank as well?
a break switch is about a 10 dollar item on the other hand a torque converter is much more something around 250 on up i would do my homework and find a good shop for a good price just remember you buy cheap you get cheap.
1helpful
2answers
2000 saturn radio is locked. how do i unlock
1.) To begin, if your radio is displays LOC, then proceed to step 2. If your radio says INOP, then turn your ignition to the RUN position, and turn the radio ON. You must leave it like this for a minimum of 1 hour (not 59 minutes) to clear the INOP message. I would wait 1 1/2 hours just in case doing it too early causes the timer to start over.
2.) Turn your ignition to RUN (if not already), and your radio to OFF. Press and hold preset buttons 2 and 3 for around 5-10 seconds to obtain a scrambled version of your radio's original factory set code.
3.) Call a GM dealer with this code. Tell them you are with a local shop i.e. I am Joe with Good Year Highway Tire; Then tell them: We have a 2000 Saturn SL we just changed a battery in and the radio is now locked. My mechanic pulled the pre-code. Could you give me the code? This usally works at no charge.
Once you have the code write it down. Keep atleast 2 copies. Hope this helps!
1helpful
2answers
Rear door lock on 2000 saturn broken. Stuck in
your gonna have to remove the inner dor panel and replace the latch lock assembly
1helpful
2answers
How to unlock Saturn gas door?
There is no other release for the door. The key fob is all there is. GM has a bulliten on the issue and your dealer will have to fix it. The bulliten number is PIT4436. Give the dealer this number and they can look it up and repair it. Good Luck
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
