water drip tray is usually located under on on top the compressor? at bottom of fridge can pull out at front or back
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
Its probably the defrost tray. Most fridges / freezers allow the defrosted water to run into a pan at the back of the unit where it evaporates away. If there is too much water, the tray cant handle it and it overflows.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valveand this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
