Question about Samsung Televison & Video
Samsung UN49KS8000FXZA Version FA01 Video Not Working
The video works for the first few seconds but then flips to fixed vertical lines in colors ranging from blues to reds. The sound continues to work fine. Does anyone know if I need to replace just one of the boards or both?
Posted by Michael Parlapiano on
Larry
  • Samsung Master
  • 3,598 Answers
It could be one of 3 things, main board, tcon board or a bad panel, does the menu look normal or does it have vert lines going through it ?
Posted on Dec 05, 2021
Which components might be bad in my Samsung LED UN65NU6900FXZA FA01 tv?
This can be caused by a loose connection on any of the cables to the display or it maybe a failed connection that is soldered at the edge of the display. If you take your thumb and apply pressure to the edge of the display all the way around in different spots and the line vanishes, it is the actual lcd edge.
Samsung UN65K850DFXZA Version FA01 display has a vertical black block but no physical cracks on the screen. Is it possible to be repaired? If so what part has to be replaced?
It is a possible defective data buffer IC on the LCD panel flex cable, if so, it could not be repaired, you need a new LCD panel.
Hi there I have a TV Samsung 46 inch model LN46B640R3FXZA It has vertical lines intermittently (more often than not) that slowly show up in different parts of the screen. Thank you Stami
Try cooking the tcon board in the oven...there are some postings on youtube that tell how to do it, if that doesn't help replace the board...Good luck!!
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
1helpful
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Open Questions:
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
