Question about Kodak EasyShare M341 Digital Camera
I have a Kodak easyshare M341 . Camera sat not used for quite awhile . Plug in it shows a long green light than 3 quick red lights. Is this battery needs changed. Because battery won't take charge
Posted by Stephanie... on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Thomas Perkins
  • 15,000 Answers
Https://www.youtube.com/watch?v=vgPvv9mhMNs
Posted on Nov 19, 2021
Is my M341 charging if the light comes on green, then blinks red a few times, then goes off????
I HAVE A CHARGER, THAT IF THE LIGHT BLINKS RED, IT MEANS THAT THE BATTERY IS NOT GOOD, & NEEDS TO BE REPLACED.
4helpful
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
My camera comes on (the green light blicks) for about one second then goes to red and won't come on. I have replaced the batteries several times
The camera turns on and there is a green light on the camera and instantly turns red
Try to use the KODAK Lithium Digital Camera Battery CRV3 There is a red light because the camera has insufficient power and also the lens assembly might be defective try to use the battery i recommend
4helpful
Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
  • remove the battery and the memory card
  • clean the metal copper on the battery
  • power on the camera without the memory card
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
Kodak EasyShare z812is Battery issue
Try using the Kodak CRV3 lithium battery, I will cost you, but the battery works. The z812is is to powerful for any rechargeable battery.
1helpful
3answers
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Kodak EasyShare M341 Digital Camera Logo
Top Kodak Cameras Experts
Ekse
Are you a Kodak Camera Expert? Answer questions, earn points and help others
