Question about LG Washing Machines
LG WM3987HW Combo - drum is filling with water during dry cycle.
During the dry cycle on my lg combo drum randomly fills with water to the point it gets an error FE. cloths can be 95 percent dry and the next minute it's dumping water into the drum. water appears to be flowing into the drum near the detergent drawer. I am thinking one of the valves is opening and i suspect the pre-wash valve. I am assuming that valve is normally closed and has no business opening during the dry cycle, unless it's getting bad signal, the control board is my thought. i power unit off and back on, clear the FE, run a rinse and spin to get the water out of the tub. i then set a separate dry cycle to run for 30 minutes, of course it has to spin first for awhile before dryer kicks in. during this spin cycle i observed the pre-wash valve open and close a bunch of times, had top cover off. again why is the pre-wash valve opening and adding water during a spin cycle. is the pre-wash valve used during other cycles other then the pre-wash cycle? at no time was pre-wash selected. again thinking bad signal from main circuit board. any thoughts? anyone have a schematic diagram of the control board? I have the block diagram from the service manual but would like to look at the circuits in more detail. I have cleaned out all lint filters, rubber seal, and condensation tube. machine settings: cotton/normal wash/rinse warm/cold spin speed high soil level normal dry 30
Posted by Neal on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
  • LG Master
  • 6,395 Answers
Sears Parts Direct is one source of the parts diagrams, https://www.searspartsdirect.com/model/1vc37q1bdj-003204/lg-wm3987hw-washer-parts . See the Dispenser assembly parts diagram for the water inlet valve. If you can watch the entire cycle, try turning off the shut-off valves for the washer inlet hoses after the rinse cycle and before the dry cycle starts. Water should not flow into the washer/dryer with the shut-offs closed.
I've seen inlet valve solenoids fail in the open position or in the closed position. I've never seen a control board that sent open messages randomly. (Sometimes, there is damage to the control board or corrosion or damaged wiring that stops the control board from sending the open/closed message to the solenoid.)
I hope this helps.
Posted on Nov 19, 2021
  • 2 more comments
  • Neal
    Neal Nov 19, 2021
    i'm certain water will not flow into the washer/dryer if water is shut off. can i run the dry cycle with the water off? i know the unit uses water flowing through the dry valve to cool and condense the moisture in the outlet duct. i was also thinking about just unplugging the pre-wash valve and see what happens. that should not be needed other then for the pre-wash cycle which i never use.
  • Cindy Wells Nov 20, 2021
    The worst that should happen is the dry cycle will stop with a different error code. I've never tried disabling one of the two inlet valves in the washer. I'm not sure if that would trigger a IE error or not. However, I'd be somewhat wary of the unit overheating. I'd want someone paying attention to the machine to stop the dryer cycle quickly. Cindy Wells
  • Neal
    Neal Nov 20, 2021
    I would just unplug the prewash solenoid. Still have four valves including dry valve working.
  • Cindy Wells Nov 21, 2021
    As I said, I've never tried that during my diagnostics. I've had more inlet errors than solenoids when failing open. Cindy Wells
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
LG WM3988HWA water filling drum and overflowing during dry cycle
Solution for finding the right part, the (5 way) Valve assembly:Part Number: AP4998623 made by LG
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520795
I got the company link from LG. If the link does not work, go the the main website and enter in the model number. appliancepartspro(.)com
p.s. I found a service manual for my unit when I removed (by unscrewing) the inside plastic piece of the pump filter. It was located to the right, in a plastic bag.
p.s.s. I checked my water pressure, it was 90psi. I think this is why my flow limiter 'shot out' the valve and into the tubing.
p.s.s.s. The dryer heater assembly, the duct out, fan, and tubing was filled with so much lint, I was surprised anything could get through.
4helpful
2answers
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
3helpful
2answers
I can't turn on SpinSense on my LG WM3987HW combo washer-dryer. I've tried pressing the button for 3 seconds in nearly every mode, on or off, locked, unlocked, wash, spin, rinse. I've managed to get it on...
I have an earlier version of your machine (WM3988HWA). What I've found is that you can't use the Spinsense feature if you've got the Dry cycle set to go after your wash. I have no idea why they designed it this way!
We run the wash first without setting it to dry, and have no problem turning Spinsense on. I usually hold it down for 3 second after hitting the start button, but you can also do it before you start the wash. When the wash is done, then we start a dry cycle.
This is the main flaw with our otherwise great machine. I posted about it at http://www.fixya.com/ThreadAsker.aspx?thid=1844295 a long time ago but never got any advice.
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
