Health & Beauty Logo
Fox's Johnnyboy Posted on Nov 18, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My loco e scooter is making somewhat of a morse code beeping noise and the lights are blinking but it won't move can anyone help
Mohammad Shoaib
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 20, 2021
Mohammad Shoaib
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
110095
Points
10
U just fix a new one soo u can drive safely
ray gallant
Level 3:
Top Expert:
  • The Master 74,163 Answers
  • Posted on Nov 18, 2021
ray gallant
The Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657539
Points
561709
Check with a dealer
2helpful
2answers
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
tip
Speakers are beeping or the status lights are flashing (like Morse code) at...
This is generally the BIOS using a "beep code" to alert you of a problem. Just write down the code (either from speakers or sometimes the status lights) being careful to record if it is a dot (short) or a dash (long). This is NOT Morse code, it is dependent on the BIOS. Check which BIOS type (e.g. Phoenix) and version you are using and lookup "BIOS beep codes" using your favourite search engine.
on Feb 27, 2010 • Computers & Internet
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
My scooter battery won't stop beeping
hi, that's sounds like the freewheel lever is engaged, please make sure it out of freewheel mode, now remove the rear axle then refit, does it still make that noise ?
Yes, okay now check the connection from the rear axle to the frame, make sure they are clean and a good connection,
Regards
www.gewizrepairs.co.uk
2answers
My scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
I haVe two golden companion scooters that worked Perfectly. One day they just quit running. I know that when the light blinks a certain number of times in the manual it tells you what's wrong. Both of mine...
Hi. 5 flashes on some scooters is the fault code for brake coil open circuit. This usually means that the free-wheel lever is in the wrong position.
Someone might have moved the levers so that they could push the scooters, and forgot to put the levers back to the correct position.
This fault code can also mean that the solenoid coil is faulty, but 9 times out of 10, it is the lever in the wrong position.
Good luck. Neil.
When i start my computer it makes a loud beeping noise it is a acer aspire4520
What you are hearing is probably a BIOS beep code.
Beep codes are a bit like Morse code, and are used to indicate certain faults with the hardware.
The codes change from manufacturer to manufacturer, but generally speaking one beep = System OK, so if your PC is starting up normally and you have no other problems there is nothing to worry about!
Hope this helps,
Matt
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
