Question about Tablets & eReaders
I found a tablet abandoned in the room I'm staying in. No logos, no name, no power supply. can I upload pics so someone can ID the thing, or should I just take it to best buy?
Posted by Steve Bratcher on
Steve P
  • 3,869 Answers
Call the manager of the place you are staying, then call the POLICE..tell them what you found and DO NOT TRY TO START - USE - or any way use it!!
Posted on Nov 18, 2021
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Screen is black but is powered on
try factory RESET but first save you info on memory card.
How do I get it to stay connected to my wireless internet?
Resolving Internet connection problems - Belkin
www.belkin.com/us/support-article?articleNum=10823
BelkinFrom wireless home networking and entertainment, to mobile accessories, energy management, and an extensive range of cables. ... Sign In · Cart0 items; Free Ground Shipping on Orders through December - Details ... How do I find my model number?... Stay tuned for exclusive offers, exciting new products and more.
My android tablet won`t stay connected to wifi network ...
www.askmefast.com > ... > Wifi
My pc tablet wont stay connected to wifi internet help ... read more ... Someone said: i have a belkin router i have just put a security setting on it all the pcs work fine put in the password but my android ..... Ok it is a slow signal using other network .... Irulutablet doesnt work unless i m in the same room with the wireless router.
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
2answers
I pad keep turning on and off while charging
A cold reset might be needed. Keep in mind that your data might be lost. If you use iTunes see if it recognizes the iPAD at all.
If it does make sure that before doing a "reset" if offers to save your data so you can restore later.
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
1helpful
I have a proscan tablet plt7777g. It will not load it turns on and gets to part where it says android but it just stays there.
First Turn off the Tablet, and locate the small pin hole reset.
Press and Hold the Power button while poking the hidden reset button with a small object like a paper clip until you see the Android logo, let off the power button.
Use the paper clip and poke the hole to navigate the menu, hit the power button to accept the menu items.
First select Wipe Data if avialable, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
This is a common problem with these off name tablets, be weary when buying cheap devices.
Hisense sero 7 liteon the drop down menu on top rite corner someone elses name pops up and when on click on it ,it does nothing. it wont go back so i can put my name and pic backu.what can i do?
You need to go into the accounts in system settings and change the account or delete the offending account.
Alternatively blitz the thing back to new condition by using system recovery mode.
Transfer pics and vids from tablet to sd card
Might be faster to upload them to the cloud than to transfer to SD card. Then you can access from anywhere.
Mark
Motorola Support
Ipad will not power up. Apple logo flashes on/off when connected to power supply
Go to the shop you bought the iPad and they will have to try to fix it if you bought it in the last year.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
