Radio Communications Logo
Question about Uniden Radio Communications
Uniden scanner won't unlock channels
  • Brad Brown Nov 16, 2021
    Hi Cindy Fansler, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model?
Guri Makeup
  • 3 Answers
Your search quest to find the <a rel='nofollow' href="https://gurimakeup.com/makeup-artist-in-jalandhar/" target="_blank" >best bridal makeup artist in Jalandhar </a>completes here for your wedding day. Guri Makeup Artist is one of the famous and top makeup artist , who is the most sought after makeup expert in Punjab including North India. <a rel='nofollow' href="https://gurimakeup.com"><b>Guri is the best bridal makeup artist </b></a>in Jalandhar, Ludhiana, Chandigarh, Amritsar, Delhi including North India .Instagram link for <a rel='nofollow' href="https://instagram.com/gurimakeup"><b>Guri Makeup Artist </b></a>
Google map link<a rel='nofollow' href="https://goo.gl/maps/ymsuxKG2mArdTCaaA" target="_blank">Guri Makeup Artist</a>
Posted on Jan 06, 2022
Can't unlock channels they are all showing l/o.
Look to see on the keyboard that has a button that looks like a key with a
border around that button. That'll be you L/O button place the scanner on
Manual then keep pressing Manual for each channel. If you see the letters
L/O << looks like that press the lock out key the those letters "L/O" Should
Disapear.. Keep doing those steps untill all channels a clear.. I say this
because this is how my Uniden 30 channel hand held works..
Yours may work diffrent? Hopefully it works the same.
1helpful
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
1helpful
3answers
Hi there I have a Uniden BC92XLT Nascar scanner, but some frequencies cannot be found. For instance the frequency range between 60 and 90 mhz is not on the scanner. How do I unlock those? Some of the...
Sorry, but there is no way to "unlock" or modify the frequency coverage of the BC92XLT or any other recently-manufactured scanner. Your only option is to purchase a scanner designed to include the frequency range that you are after. If you don't already have it, you can download and print the operating instructions for your scanner here:
http://www.uniden.com/pdf/BC92XLTom.pdf
Bill B
2helpful
Have l/o for all channels. but can't get them
To unlock a channel, power the scanner ON, then press MAN, the channel number, MAN again, and then L/O. Lockout will also show if no frequency is programmed into a channel, and programming a frequency will automatically release the lockout.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
BillB
1helpful
Lockout message
Uniden has a webpage with a free manual pdf download for your scanner.
You'll be able to get the manual HERE The link is upper right side of page..
If all your channels are locked out, press and hold the l/o button for at least 2 seconds, you'll hear 2 beeps and that should unlock them.
3helpful
2answers
Uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
Scanner problem
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
19helpful
8answers
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
1helpful
Can not unlock channels
http://www.uniden.com/pdf/BC60XLTom.pdf
Top Uniden Radio Communications Experts
Robert McClure
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
