Question about RCA Audio Players & Recorders
Have they found a way to connect Bose Acoustimass 9 subwoofer to the back side of a Pioneer VSX-524 K Receiver?
The acoustimass 9 has a 8 pin Din plug thats turns to 2 RCA and 1 3.5mm plug.How do you connect that to receiver with 1 RCA hole?
ADMIN Eric
    Top Expert:
  • RCA Master
  • 37,888 Answers
Subs are mono so just insert one plug.
Posted on Nov 16, 2021
Testimonial: "Thanks for the answer, but I still need more information, because the Acoustimass 9 controller unit has 3 cables cominng out, 2 RCA n one 3.5 mm, what I do with the 3.5 mm cable.Another thing the Pioneer has a sub pre-out, can I use that?"
Can I use a Pioneer Elite VSX- LX101and a Bose Acoustmass 9 powerized speaker system.
You are only given one answer from our Expert Ray with the brief answer 'No sorry'.
This is your VSX
REAR TERMINALS
HDMI 4 in
HDMI 1 out
AV (Composite) 2 in
Audio 1 in (assignable)
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 0.1ch (SW)
Speaker 5 ch out (FRONT, CENTER,
SURROUND)
and this is your Bose. Find the manuals for both and read them. connecting them
https://www.techwalla.com/articles/bose-acoustimass-9-speaker-system-installation
A: Glancing at the specifications of the Bose Acoustimass 10, the system is stated to be compatible with A/V receivers and amplifiers rated from 10-200 watts per channel, and from 4 ohms to 8 ohms. Aug 17, 2014
Q&A: I Have A Bose Acoustimass 10 System, What Receiver ...
It is a pity you don't have a newer one that can be connected via HDMI lead.
Which pins on a 13 pin plug for a bose powered acoustimass 25 series II module would i use just for subwoofer
I know this is late but might help someone plus I had to repair the audio input cable going from my acoustimass 25 series II to the Lifestyle 5 receiver. The 13 pin connecter cable terminates to 2 RCA jacks (red/white) one 3.5 mm jack and a female RCA which is the digital sound source. looking at the connector with the 13th pin on the bottom, I reference the pins from 1-13 starting at the top left:
PIN 1 RCA (RED) center conductor
PIN 2 RCA (RED) sleeve
PIN 3 RCA (digital) sleeve
PIN 4 RCA (digital) center conductor
PIN 5 RCA (WHITE) sleeve
PIN 6 not used
*PIN 7 3.5mm RING (?????)
PIN 8 3.5mm SLEEVE
PIN 9 RCA (WHITE) center conducto
PIN 10 not used
PIN 11 not used
PIN 12 3.5mm TIP
PIN 13 not used
* the 3.5 mm stereo jack is used for system control on the back of the lifestyle 5 receiver, the cable that terminates to the 3.5mm is a 3 conductor cable that terminates to PIN 8 & PIN 12 but PIN 7 only has continuity from the pin itself to the white cable (within the 3.5mm cable) but not all the way through to the 3.5mm ring (where i would assume it to terminate). Maybe this is where my problem is, I don't know but I spliced the cable right before the 3.5mm jack and there was continuity between PIN7 and the white cable that corresponds to the 3.5mm jack I just dont know where its terminating too. If anyone can confirm that it is supposed to terminate to the ring of the 3.5mm connector I would appreciate it.
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
1helpful
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Need wiring assistance
Just need to register, login and you can download manual from here.
It will take only two minutes.
Hope this helps.
4helpful
3answers
Acoustimass 9
Acoustimass 10 IV cable
6helpful
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
