Question about Tablets & eReaders
10.1 tablet how to reset the whole that's the technical settings back to factory settings
Posted by Jason Perrault on
ADMIN Canada
    Top Expert:
  • Tablets & eR... Master
  • 41,541 Answers
It is a standard Android System Reset.
Press and hold the Volume Up + Home + Power button, until you see Samsung logo and release all buttons and wait for the factory reset screen to appear. On the next screen, choose "Yes" and press the power button to confirm the whole operation.Apr. 12, 2019
How to Hard Reset Samsung Galaxy Tab A 10.1 - Swopsmart
https://www.swopsmart.com > blog > hard-reset-samsung-...
About featured snippets
Posted on Nov 15, 2021
2answers
How do i unlock my tablet if i forgot my password?
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
1helpful
2answers
There are no instructions on how to reset my grandsons kurio7s tablet
check out http://www.kurioworld.com/k/us/parents/support/7/gettingstarted
Kurio7s
In order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
Please feel free to contact Kurio Technical Support on our support page.
Reset to factory settings on Samsung galaxy 10.1
Go to applications, settings, back up and reset. If you want to save your data check the "back up my data" box, then tap the "factory data reset" and tap the "reset tablet" tab. The tablet will then be reset to the original factory settings.
How to reset factory settings
On your tablet, tap on Settings > Personal > Security. The reset to factory settings option will be near the bottom.
Reference: Lenovo Yoga Tablet 10 User Guide.
https://www.cellphones.ca/upload/manuals/lenovo-yoga-tablet-10-manual.pdf
Hope this helps!
Factory reset Kocaso M760
Try this before you do a factory reset by loading the firmware again.
3answers
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
