Toys Logo
Question about Toys
I have a y shaped extension cord for the remote on a carousel but have no idea how it functions. I have a photo of the three plug ends.
Two yellow plug ends with five pins each - 1 is labeled 150 hz and the other 1000 hz. And then there is the black plug end that has no label.
Posted by Paul Preuss on
  • ADMIN Andrew
    ADMIN Andrew Nov 15, 2021
    Guessing it is a Toy Carousel, but equally, it could be a projector carousel. Please always include FULL 'make model (what it is)'.
1helpful
What to do with patio lights at the male and female plugs that don't extend to outlet?
Get an extension cord (outdoor), or have an electrician add a longer cord. If you add an extension, you might wrap the plug/receptacle with plastic electrical tape to protect from rain. Make sure well grounded with three-pronged extension cord.
Jump it 1000a does it come with a plug. If so I can't find it can I use an extension cord
Does not come with a cord plug. Manual can be found at link below. from the manual :
When an extension cord is used, make sure that: a) the pins of extension cord are the same number, size and shape as those in the charger, b) the extension cord is properly wired and in good electrical condition, c) the wire size is large enough for the AC rating of the charger.
Manual Link: https://smedia3.webcollage.net/ddef711707ceced1384e8307a60b5baf31f83669?Signature=uc936gqXfXQ2NLpvAY8j%2BTIZUwY%3D&AWSAccessKeyId=AKIAIIE5CHZ4PRWSLYKQ&Expires=1893496000&response-content-type=application/pdf
1helpful
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Dubbing from vhs to dvd but when trying to playback dvd it comes up blank
Install all three 3 RCA plugs to output of vcr,, other end of wires 3 RCA wires plug into right front of recorder then push record. Be sure red to red, white to white, yellow to yellow or you might have a bad RCA cord. Remote set source to E2.
The plug at the end of the headphone is wearing out
I don't know if this might help, but see my tip on replacing dodgy cable and plugs on headphones.
1helpful
Carousel does not turn. Cord remote does not move it. Forward and back pushbuttons on case do nnot move it or make a sound
Because you don't specify a model, I will assume it is an older generation, manufactured in the 60's or 70's. These series had a part called the "link", which was made of plastic. This "link" connects the cycle solenoid to the slide change mechanism. With age, the "link" becomes brittle & cracks, rendering slide change non-functional, regardless if you use the side buttons on the projector or the remote control. This is a difficult repair, but the parts are still available. I recommend you contact a factory-trained repair dealer to fix your projector.
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
1helpful
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Open Questions:
Top Toys Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Toy Expert? Answer questions, earn points and help others
