Question about Kenwood Car Audio & Video
I have two Kenwood kfc-w3013 ps sub in ported box the rms are 400 a speaker and 1200 max a speaker and they are in a dual box please I need help on what will be there best amp to push these thank you
Posted by Derick Clayton on
1helpful
Wiring Kenwood KFC-W3003
If it's a single voice coil, it's probably 4 ohms. the sub only handles about 175w RMS, so don't expect earth shattering bass to come out of it. A single voice coil is easy. Positive from the amp to the positive post of the sub, negative from the amp to negative post of the sub. This sub sounds lots better if it's in a sealed enclosure. A ported enclosure allows too much cone movement, heating up the coils, and the sub fails prematurely. Hope this helps.
I have a set of kenwood 5-way 7x10'' speakers (4oahm,90watt rms,500watt max) and a kenwood 12'' sub (4oahm, 200watt rms, 400 max, 800 peak) and my question is if the kenwood kac-706 4ch amp...
Did you google for the specs? Gotta be there. Meanwhile the amp will drive your speakers - the issue is if the amp has enough power to drive the speakers to the volume level you want without distortion. Whatever you decide be careful with speaker wiring and do not hook them up in parallel lest you want to toast your amp stages to a crisp.
1helpful
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
I have two 12" kenwood KFC-W3003 4 OHM 600 Watt Maximum Impedance. I have them both in a sealed box with a divider in the middle, it sounds good and loud but i want deeper bass that will make your...
the cheapest way is to get a prefab box from sonicelectonix.com get it ported im hittin 130db with mine in a 2.3?cu ft center port(one big chamber). litterally my fiance cant drink anything cant smoke a cigarette, and all hell breaks loose when i have the window cranked and throw 400w rms at the pair so bout 200 ea. and that my friend makes my ears hurt very bad and they actually hit harder than my older style RE audio subs.
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
1helpful
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
1helpful
Blown subwoofers
Does the amp have an input 'clipping' LED? The worst thing for a speaker is to try and reproduce an unclean signal. Just make sure not to overdrive the amps input. You might also purchase higher rms rated speakers. As far as the ground is concerned, paint and/or oil, rust etc have been cleared from contact area, correct? Seems like if ground were insuffecient, power to amp would drop out.
I have a Kenwood KFC-W3514DVC and its hooked up to a Valor Multimedia VPA402 500 watt 2 channel amplifier. If i want to optomize my system the cheapest way should i buy another subwoofer or should i buy a...
find the rms rating of the sub and compare it to the amp.if the rms of the amp is higher than the sub you have enough power to push the sub.if its lower look at the rms of the amp if it can be bridged.you would like to see the rms matched to the sub or subs if you have enough power.
1helpful
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
Ported box sq. port speces
  • ported box volume: 0.75-1.75 cu. ft.
  • Not finding what you are looking for?
    Car Audio & Video Logo
    Top Kenwood Car Audio & Video Experts
     Francisco Mauricio...
    Jeffrey Turcotte
    Jeffrey Turcotte
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
