Frezzer control knob not working
Howto order a new one
Posted by charles McKenzie on
  • Anonymous Nov 13, 2021
    post to freezer not computer, gee, ? call for service we can not fix it lacking parts.
    no model freezer told nor maker, 3 errors in 1 post,
    yp.com find the appliance repair persons.
    https://www.fixya.com/troubleshoot/brows...
    does that mean , knob is missing, loose or dead or slips, or only means freezer side will not get fully cold.
    can not see you turn the knob or feel it. no can do.
Liv Jakobsen
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Try looking up the exact model number of the refrigerator on Ebay to find replacement parts. It can be difficult, if the model is older than 15 years.
Posted on Nov 29, 2021
Cant find where you ture down the frezzer
Did you mean TURN down the freezer? There should be a knob at the back where you can control the temperature for the freezer.
2helpful
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Both the frezzer and frig do not get cold. Hear clicking noise turning on and off.
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Cannot set Control dial for wash cycle. Knob will not move indicator dial. Rotating without engaging indicator. Thanks
Pull the center knob strait off. I suspect the center shaft of the knob is broken. If it is order a new knob but before replacing it make sure the shaft on the timer does not have a metal sleeve from the knob remaining on the timer shaft. Temporarily you can try to use needle nose pliers to turn the shaft to see if the washer works.
7helpful
3answers
Need replacement knob for Parrot Bluetooth car kit MKi9200
Went to Radio Shack after we lost the knob to our MKi9200 and bought an Insert Control Knob. The blue one is model #274-403. It also comes in red. They are sold in a two-pack for $1.99.
http://www.radioshack.com/product/index.jsp?productId=2103790
To install it, first you need to file off the plastic pointer on the side of the knob so that the knob is perfectly round. There is a small screw on the side of this knob so that you can tighten the knob to the post on the remote.
Advantages of this knob over the original Parrot knob are (1) the knob _never_ falls off, and (2) there is more tactile feedback when turning the knob. I like the asthetics of the blue. The only drawback is that it is more difficult to spin the knob quickly in long lists.
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Frezzer to cold and Frig is cold a little
Dear customer,
                     It maybe the makfunction of defrost timer howevet we recommend you to do the following before checking the defrost.
  1. Check the temperature setting
  2. Test the  temperature control
Click on the highlighted words to know how to test them.  If they seem to work fine then check defrost timer using the reference link  http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
Thank you..
2answers
Possible frezzer sticking in defrost
The defrost clock may be starting to go bad. It will intermittently get stuck in defrost. The next time the unit warms try to locate this clock. Advance the knob and if the unit turns on you know the clock is getting stuck. :)
Computers & Internet Logo
Ekse
