Question about Armitron Watches
My armitron sport watch (ladies) eith velcro straps, the reset button doesnt chirp and wont allow me to change times
Posted by Denise Cook on
WHERE CAN I FIND THE MANUAL FOR THE ARMITRON 40/8284 PRO SPORT WATCH?
hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
Instructions to Set the Time on an Armitron Pro Sports Watch
or try this.
How do you set an armitron pro sport watch? Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
Instructions to Set the Time on an Armitron Pro Sports Watch ...
https://www.livestrong.com/.../247211-instructions-to-set-the-time-on-an-armitron-pro-s... Search for: How do you set an armitron pro sport watch?
or read up on this link.
MANUAL FOR THE ARMITRON 40 8284 PRO SPORT WATCH Google Search
23helpful
Set the time on a Armitron WR330 40/8125 All-Sport watch
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Need to set time, etc on this 3 button watch
Hi
I have found a PDF document that contains instructions for all ladies Armitron digital watches it can be found here. It dosnt however contain instuctions for your model, but most of the watches it covers have the three button setup and may fucntion the same way.
Hope this helps
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
Hope it helps.
6helpful
Changing the time on my wristwatch
Hold the "reset button" about 30 secs, than the hour starts flash and you can change them pushingst/sp button. Martin
42helpful
2answers
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
124helpful
3answers
Ladies Armitron 45/6967
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
1helpful
2answers
Instructions for ladies' Armitron 45/6974
From the instructions that came with the watch:
Press the button at the top left to get into time change mode, press on the bottom left button to move between seconds, hours, minutes, etc.
Press the top right button to change numbers; hold to move quickly.
Watches Logo
Top Armitron Watches Experts
Ekse
Jimmy Accardi
ray gallant
Are you an Armitron Watch Expert? Answer questions, earn points and help others
