You'll need to do a factory reset: 1. With the device off, press and hold Volume Up and Power. 2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears. 3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection. 4. Press Volume Up continue.
First, make sure the sound source is indeed outputting sound. The green light will only light up if there is a proper source. Then, find a good combination of volume level and tunning. Note that that the volume will affect tunning. Play around with both. Leave them both in the middle. Then move the dials until you find a good combination.
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv.
I hope this helps!
-Der Strom
Protected in short means that the amp is no longer powering the speakers due to one of the following:
1. Volume is up too loud
2. Equipment Failure
3. Dirty power
Turn amp on by pressing the function button on the remote of a source that has nothing on it or is not powered on. If it still says PROTECTED even though you are on a source with no sound coming in, then the equipment is in need of repair. If it simply comes on normal displaying the source turn the volume down till it says MIN. Find the range of your speaker and amp power by selecting a source with music or movie audio and slowly turn it up till either its too loud or says protected. Be sure to double check all speakers and wires to ensure wire integrity as well as proper connection.
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
This is easy, Press in and hold the function button and the volume dial,.. after the function menu comes up press function again to get to Aux off.. press up to get it to Aux 1 and then press in the volume dial again and youre set!
