I would have guessed your washer may have alot of dirt and dust inside if its got alot of usage. How old is it. How long has it been happening. If its new you may want to check the amps for the machine and then ask is the outlet rated for that amps. If its 20 amp machine and your outlet is 15 and the breaker is also 15amp its going to need a better wire upgrade.
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
