My wheel writer 5 is stuck in Caps Lock,
Before that it was only typing in Caps, and unable to type numbers
Posted by JoAnn K Theriot on
  • 2 more comments
  • Larry Ng
    Larry Ng Dec 15, 2021
    TELL WHAT IT IS FIRST is it a computer or printer? ( last time I had 1 thing with that name was printer diasy wheel printer or typewriter.
    did you mean
    IBM Wheelwriter 5 circa 1985 ?????
    "a REAL TYPEWRITE, NOT FOUND IN LAND FILLS WOW, SHOCKING"
    do some folks still use type writers? really? for me this ended back in 1979 , with app, called wordstar
    well that key is stuck, find a shop that fixes old things with old man behind the desk like me,
    the key is bad, or the shift key seems more like this based on top row of numbers, wrong. shifted stuck
    a simple problem clean the shift key switches, or springs on them dirty or broken or jammed.
    its just switch nothing magic like lame membrane keyboards now.
    1985, IBM the oldest posted object here not a computer at all. WOW , I AM STILL USING LIQUID PAINT ON CRT screen EVERY TIME I TYPE WRONG. (Correct type?) wifi get mad but fun to see her scream so loud.
    "How many time must tell you hit backspace" yes, dear.
    my oldest is a ASR33 teletype, connected to my 1979 micro. (north star S100) and runs Wordstar.
  • Anonymous Dec 15, 2021
    may asr33 only does caps. we typed in caps for ages then, from the first micros.
    in Viet Nam all traffic in caps, and puncts limited.
    and not once did we ever think to fear a cap. not one second. like today., wusses.
  • Larry Ng
    omg first hit
    https://www.youtube.com/watch?v=Q18bnX9M...
    says no fix, the key matrix is not serviceable, but if bad,a nice flush with IPA and then bake it dry might fix that.
    one guy said drill out the rivets , clean it then use tiny screws to fix it all back.
    find a good used board off ebay, just 36 years last?
    i see one for $100
    flush and bake it seem good, IPA and put it in a hot attic, until 100% dry.
    IPA ask any nurse what that means (white lighting or ever clear, moon shine?)
    many times i key sticks do to coffee or worse cola spills, IPA cleans that out.
    switches can conduct with filthy fluid spills.
    screws scan be had down to 1mm or less. to replace rivets.
Larry Ng
  • Computers & ... Master
  • 6,445 Answers
Yah that.
Posted on Dec 15, 2021
    I wonder if there is youtube on that IBM for key service.
ADMIN Canada
    Top Expert:
  • 42,943 Answers
Larry writes
  • TELL WHAT IT IS FIRST is it a computer or printer? ( last time I had 1 thing with that name was printer daisy wheel printer or typewriter.
    did you mean
    BM WheelWriter 5 circa 1985 ?????
    1985, IBM the oldest posted object post here not a computer at all. My oldest is a ASR33 teletype, connected to my 1979 micro. (north star S100) and runs wordstar.
I guess you could repair it, or you could donate that antique to a museum :>)
2answers
CAPS LOCK DOESNT UNLOCK
if you hold down the Shift key and type are the letters small??
sounds like your Caps Lock key is stuck
My Lenovo laptop types symbols when I type figures. I also need to use caps when I need uncapped text and visa versa. Can you please help
sounds like your keypad is not set up right try going in to control panel and click on keyboard and try to set from there.
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
1helpful
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Can I type numbers w/ the caps lock on?
You can type #s with caps lock on but not with shift lock on. Shift lock and cap lock are not the same. To get to caps a code and a key labled caps must be pressed.
DickyO
5helpful
2answers
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Problem with sony vaio keyboard
Sounds like you've got something stuck under your shift key. Carefully clean out under the keys, try a paintbrush and a hoover (on low suction if possible).
Be careful not to knock any of the keys off. They're held on by small clips which pop out or break easily.
13helpful
4answers
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Computers & Internet Logo
Ekse
