Question about Vizio E420-A0 42" LED TV 1920x1080, 60 Hz, HDTV
How to unclip and remove the back of a Vizio E420-A0 TV?
I've removed all the screws, but the back panel is clipped in place by clips of unknown design in unknown locations. Where are they located and how does one release them? Answer: With the tv resting on its wide edge, using a pair of short stubby flat-blade screwdriver, start at one corner and insert one into the seam between the two pieces and rotate it around its axis to begin spreading the seam. As soon as it's practical, insert the second screwdriver, and begin moving the first one further away, stopping periodically (every 2-3 inches) to rotate. As the distance increases, begin rotating with more force, and eventually, one of the holding pins will finally unsnap and progress will be easier. Continue in this vein, attempting to unsnap every few inches. In the case of the E420-A0, no wires are connect the back to the rest of the set: once completely unsnapped all the way around, it comes off easily.
Posted by oert on
Tv stand screws
Contact the authorized dealer. They can either provide you the screws, or can lead you the place from where you can buy it. Otherwise you have to download the repair manual to this set. Its disassemble section will have these details.
Gopakumar Gopalan Google
1helpful
Wd62p replace hinges
First of all remove the door from the machine by unscrewing the screws on the hinge than remove clip at the top of door seal, when it unclips remove metal band, pull front of door seal off of front panel, Pick up metal bracket. Now with the hinge attached to door hold in place and place bracket behind the two holes fit screws and then fit the seal and clip.
Regards
Remove drivers side inside door panel
1. Disconnect negative battery cable
2. Take a flat head screw driver pop out the little eletirc panel on the door and with all the eletronic switches on them.
3. After removing the eletric switches you will notice a screw that holds the door panel, remove that screw with a phillips screw driver and unclip all the eletronic pieces..
4. Check the panel for a screw near the bottom left corner of the panel there was just a screw hole on mine but there may be a screw on yours and remove it.
5. Grab the bottom of the door panel and pull upward hard if the clips do not remove themselves with upward force use a flat head screw driver to pull them up don't break them.
6. Once all of the clips are screws are disengage detach the trim panel disconnect any electrical connectors and remoe the trim panel from the vehicle by gently pulling it up and out.
7. For access to the inner door remove the door panel support bracket then peel back the watershield taking care not to tear it. it install the trim panel first press the watershield back into place. if necessary add more sealant to hold it in place.
8. Installation is the reverse of removal
Viola
5helpful
The rear wiper on my 99 Bravada has quit working. It made about 2 passes over the window before it completely stopped. How do i go about replacing the rear wiper motor?
Unscrew inside panel on tailgate (3 screws-1 each side, 1 in the middle), unclip and remove by pulling up and out towards the rear. Unscrew all screws holding steel plate down, unclip plastic clips that hold the rod running behind the plate and unhook rod at top of that opens the window. Unclip wiring harnesses, remove wiper from the outside (1 nut holding it down)and unbolt the motor. It is pretty self explanatory once you have the steel plate removed, just remove and install the screws and clips in the same order and try it out before you put all your screws back into the steel plate since there are so many. Back window must be closed for wiper motor to work. To save yourself from replacing the motor with a new one, 9 out of 10 times it is simply the locking washer has come off of the gear inside the motor, if you pop off the plastic motor cover you will see the washer is off the gears are out of place. I realigned the gear and replaced the washer with a "C" clip and it has been working great for over a year!
1helpful
How do i remove the radio from the dash 1998 hyundai accent
Hi
You have to take out the ash tray, and remove those two screws, then pop out the center dash trim. Careful, though, you have to take out a lot of the wiring inside of your center dash trim in order to pull it out for enough room to move the radio in and out.
OR more elaborately try the following:-
1. Remove the panel under the steering wheel. There should be four bolts - the two at the top are covered with plastic caps. When you have removed the panel, take off the two climate control cables that run to the air controls on the dashboard. They should be secured with clips which need to come off, and the wire centre is wound around a small control knob which should have a push in clip so the wire can slip off.
2. Make the glove box drop down by removing the two plastic clips at the back of the inside of the glove box. These clips are the glove-box buffer stops and should spring off and can be pulled through the clip-opening. Behind the glove-box is another wire to un-clip, but this one slips straight off the metal control actuator.
3. Remove the ash-tray by pressing the spring loaded metal part down and take the two screws out at the back of the ash-tray. You should now be able to unclip the central dashboard. Use a screwdriver to lever it away gently, and watch for the small metal clips that drop out as you do so. As you pull it away the cables you unclipped will come away from their place and come out with the dash unit.
4. After pulling the dash-board out a few inches you should be able to see the seating screws for the radio. Take all the screws out and pull the radio forward. By unclipping the cables at the top of the unit you will find you have enough play to pull the driver's side right forward and jigger the head unit out of the gap on one side of the unit.
Thanks for contacting fixya.com
6helpful
I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
1helpful
2001 nissana sentra door panels
There should be a screw where you put your hand to close the door and a screw under the door latch remove both of those. next pop the plastic clips out that hold the panel in place by prying on them with a flathead screwdriver being careful not to scratch the paint. now the door panel should move but wont be completly off. next reach behind it and disconect the two rods by uncliping the clip on each one. if you have power locks and windows disconect the wire harnesses by pulling them apart they usualy have a tab you have to push to unclip them.
7helpful
2answers
I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Vizio E420-A0 42" LED TV 1920x1080, 60 Hz, HDTV Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
