Question about Tablets & eReaders
Onn 7" tablet model 10005206 manual
Im looking for owners manual or repair guide for my tablet. My daughter dropped it and the volume and power buttons either fell inside the tablet or fell off.
Posted by Jennifer Tinch on
john h
    Top Expert:
  • Tablets & eR... Master
  • 25,705 Answers
Owners manual not going to help a damaged unit can contact at https://1800customersupport.com for manual and or at 1-888-516-2630 1-877-252-6873
Posted on Nov 11, 2021
Bought a used Onn Tablet. It won't let me sign in. I don't have PIN or the owner persons user name. It's locked anyway to open / unlock it.
Tidied up the question into the Queen's English :>D
You need to do a hard reset, also known as a factory reset. This scrubs the tablet clean and reloads the Android operating system with no password set.
Power Off
Press and hold the On button and the Volume Up Bottom for 12 seconds.
When you see the Recovery console, Choose the Factory Reset option.
https://www.devicesfaq.com/en/reset/onn-n2t
Text based articles and Videos
https://www.google.com/search?q=onn+tablet+hard+reset
I boughr my daughter a rca tablet model rct6773w22 she put a pattern lock on it and.dont remember what the.pattern to unlock.it is how.do.i reset it so it can be.used
you dont,thats why you write down those patterns,now you have to hard reset and lose your info,but,here ya go,
Follow the detailed instructions below on how to completely reset your RCA Android 7 Voyager (RCT6773W22) tablet.
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
Ok my daughter has a alldaymall 7" 8GB tablet model:a88 she set a pattern for password and now doesn't remember the pattern and there's no reset button any suggestions on how to reset would be awesom
Switch the tablet off. Press and hold the volume up/down buttons then switch the tablet on, keeping the volume buttons pressed. This should start the tablet in service mode. You should be able to restore the tablet to factory default from the options in the service mode.
Where can i find the charging port piece im looking for?
If you look at the First picture on the TABEO User guide it is a little hole next to MicroSD slot on the side of the tablet
the user Guide is here
http://tabeo.support-tablet.com/download/e2/e2-startup-guide.pdf
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
17helpful
How do i do factory reset on sanei n91 tablet
How do i do factory reset on my daughters sanei n91 tablet she lost pattern lock and had tablet in flight mode so cant recover from email holding power and volume does nothing for reset.HELP
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
