7254v remote bips when arming or disarming with a new battery
Has a new battery 2032
Posted by Ed CHEVY on
  • Anonymous Nov 10, 2021
    what computer is this , posted to same.
    what is bips, = beeps?
    left out the words HOME ALARM system and expect the blind to guess?
    alarms belongs here.
    https://www.fixya.com/troubleshoot/brows...
    or ask you alarm maker directly,
    the name is VIPER, right, and not told.
    so you meant
    CAR ALARM REMOTE START SECURITY SYSTEM KEYLESS NEWEST MODEL (the man killerr device )
    bingo not PC, not home alarms but cars.
    I click cars
    I click acessories
    I click viper
    just 3 licks and land
    https://www.fixya.com/troubleshoot/viper...
    seem to me you lost the manual and in it how pair it to the base>? so when some folks have 2 remote clickers
    each is paired to work independently
    RTM
    get the manual from VIPER free and read it. ask them for that and not lose it.
  • WandCrockett
    WandCrockett Nov 10, 2021
    . [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://www.netcash1.com
Mehandi Husain Suleman
  • Computers & ... Master
  • 1,654 Answers
Hi
If you want to reset your Viper alarm, you can do so with your car's fob key.
  1. Point the fob key toward your vehicle as the alarm sounds.
  2. Listen and wait for your alarm to sound for six seconds. Press the lock button on your key. Your vehicle's Viper alarm will reset but the alarm will still be armed.
Posted on Dec 17, 2021
How do you work 2006 street glide push button key fob
1 long push on the remote turns it on and 2 quick clicks turn it off.
Disarming function may require practice. The key fob button must be pressed twice within 1.5 seconds to send the disarm command. The action is very similar to double-clicking a computer mouse. Light quick taps work best; very hard or very slow taps are less likely to work. The key fob sends a RF signal to activate all remote TSSM functions. The left front turn signal switch wire serves as the vehicle's antenna. If the TSSM does not respond (no confirmation at arming/disarming system) or responds weakly (limited range, won't consistently arm/disarm or synchronize),
Verify key fob battery voltage is at least 2.9 volts. Replace the key fob battery every 2 years.
Interference from physical surroundings may affect RF transmission. Place the fob next to left hand grip and disarm with two clicks or move the motorcycle to a new location and try again.
Check for damage to antenna wire. Does left turn signal work?
After a battery disconnect, the TSSM will not enter the configuration mode on the first attempt. All attempts to assign a fob or enter the configuration mode will require at least two attempts.
The TSSM system uses batteries in the key fob and siren. These are the only parts requiring periodic maintenance.
Battery Replacement
Open the key fob case, place a thin blade between the 2 halves of the case, slowly twist the blade remove and replace battery positive + side down, use a Panasonic 2032 or equivalent, align the case and circuit board, snap the case halves together, while standing next to the motorcycle, press and hold the key fob button for 10 to15 seconds until the security system responds with two turn signal flashes/siren chirps.
Car does not arm or disarm when door opened alarm goes off
Hi, I love the viper. Mine worked flawlessly for many years until one time my unit would not arm or disarm. Obviously 1st I checked batteries which were good. I took mine to installer and they said I had a remote go bad. He got me new remote and that was it. Sometimes I wonder if somehow I managed to hit a factory reset sequence on my remote. Considering your also having an issue with door contacts as well, I would hope it's not the main unit. My system also had a special override switch in the footwell, if you have one, perhaps you may have switched accidentally. Hope this helps in troubleshooting.
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Avital alarm won't arm/disarm.
My remote will not unlock my truck or disarm and I put in New batteries. What do I need to do
2answers
How can the sensitivity of the 9966 alarm system be modified with the remote control to the most sensitive setting (there must be four settings...)? I cannot read the Chinese original manual! After...
I have the same problem. If you figur it out please e-mail: [email protected] instruction it says press disarm button 3 times then arm for 3 times- i hear bips but not changing
1helpful
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
2answers
05 Dakota remote wont work
That happened to mine too. Is it a "Karr" remote? If so, it seems as if they use really cheap switches. I ended up de-soldering a working switch from the trunk release circuit and soldering it onto the alarm arm/disarm circuit. Works perfectly now. If you don't own a soldering iron, I recommend getting a new one or getting a better alarm system.
1helpful
1995 Nissan Maxima alarm system
Hey, I bought my 1995 Nissan Maxima GLE brand new back in July 1994 with factory installed alarm, it just doen't make any sound when you arm or disarm it with remote. The only way you can tell whether it is armed or disarmed is from the lever position of your doors and the blinking red light under the dash. Only the newer versions of Nissan/Infiniti's has the "Audio/Silent" mode button on the remote which allows you to activate/deactivate you car alarm with an audiable sound or no sound at all. No worry, there is nothing wrong with your remote or car alarm.
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
1helpful
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Computers & Internet Logo
Ekse
