I have had an honestech 7.0 Deluxe for years, but have problems reinstalling it on my Windows 10 laptop.
Posted by Reg Blakeley on
  • KathleenChinn
    KathleenChinn Nov 09, 2021
    [ JOIN US ] I get paid more than $60 to $90 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $21000 from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.…………>>http://www.netcash1.com
Larry Ng
  • Computers & ... Master
  • 6,585 Answers
To buy just software is $50
so you have the CD
the last version 7.x did w8 max
so at the setup. install dot exe
right click that and pick run in compatibility mode as MS tells you to do.
the free version seen on line is crippleware.
what you have there (install media, i can not guess)
mfg, web site link in manual is DEAD, EOL, dead.
most free online sites with this are fully max infected,
any thing that is dead, then is virus infected in the vacuum of dead.
a brave new world.
Posted on Dec 22, 2021
1helpful
I purchased the Audio Recorder 2.0 Deluxe several years back. The *********** is: ARD2G-SEP96-4H338-D45ED-CFE3C.. It is compatible with Windows XP - 7. Can this be used on macOS Mojave, 10.14.2?
Hi there, this should help
no-maybe
so the software is made to run on mac and 2 you may be able to use something like boot camp and there is no kind of guarantee it would even work period and no way to check besides trying it. Good luck
https://www.honestech.com/main/AudioRecorder20Deluxe.asp
https://www.6ya.com/mr.mike
2answers
How do I uninstall windows 7 home premium to reinstall when there is a problem that won't let it load ?
There is no way to uninstall it, if you have to you will need to re-install it again. Before you go the drastic route you may be able to fix the problem, depends on what the problem is. You need to be very specific about what its doing, or not doing and if you are getting any error messages when you try to start it.
How do you make it work in windows7
I found this on a forum....I hope it helps!
This review is from: VHS To DVD 4.0 Deluxe [OLD VERSION] (CD-ROM)
I needed a way to connect my PS3 to my PC so I can take some screenshots and I only had 2 days to do this so I searched Amazon for VHS to DVD's and this was the one the best rated products. Next I went to Honestech to make sure Honestech VHS to DVD 4.0 Deluxe was compatible with Windows 7, and it was. So I rushed down to my local Fry's Electronics to pick one up, price was about the same so no problem there.
Problem:
Once everything was installed hardware/software/drivers, I ran the Honestech software and after a few minutes of running my PC just locks up. So I rebooted and tried again, but again my PC locked up, now I am confused since they said it was Windows 7 compatible and I did get the latest software from Honestech site. I first thought it was my PC but after some testing I did discover that it was Honestech software that was locking up my PC.
Solution:
OK so here is what I did to make it all work, forget the Honestech software you don't need it. Go to Honestech site and get the drivers for "HT VIDBOX NW03" this is what comes with the Honestech VHS to DVD 4.0 Deluxe. Download and install the drivers and restart, go into Device Manager and make sure you are not getting any device conflict and that everything is installed right. On Windows 7 the only thing I saw that Windows 7 didn't have drivers for was the audio, so installing these drivers fixed that problem. Now Google Virtualdub, it's a free video editing tool, Open Virtualdub go to File and select Capture AVI. Now under Device go select your USB2.0 VIDBOX NW03 (DirectShow), you should now see video coming from your HT VIDBOX NW03 go to File and select Set Capture File, enter the file name you want your video file to be and where you want to save it and hit save. Now go to Capture and hit Capture Video to start recording, and it Capture Video again to stop recording, that's it you are done.
2answers
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
2helpful
I am using win7 so i open honestech tv tuner i get open webcam
Ibrahim Please State your Details properly first! and If you are facing problems with your TV Tuner card Card in Windows 7 Please use TV Expert Software instead of Honestech and First Disconnect your Webcam, install the TV Tuner Card drivers properly, install the TV Expert Software for you TV Tuner and Try to run the TV. I am also using Win 7, Philips TV Tuner installed with TV Expert Software and a web cam but no problem here.
12helpful
2answers
I install Honestech TVR 2.5 on my computer with Windows 7 Ultimate and any time I restart, it ask me for SAA7134. The Honestech VTR 2.5 works without any sound.
Listen to Swamiji..................................
1.Click on start --> All Programs-->HonesTech TVR.
Right click on it and choose propertiers and then go to Compatibility tab and choose XP SP2. and then run application and it start working.
Baba Banketeshvar Narayan Swamiji Maharaj
17helpful
6answers
I have recently bought an Intex Gravity USB TV tuner box. It uses Honestech TVR 2.5 as its main software. I am using Windows 7 on my Compaq Laptop. The dealer had assured that TVR 2.5 is compatible with...
i have recently bought an Intex Gravity USB TV tuner box. It uses Honestech TVR 2.5 as its main software. I am using Windows 7 on my lenovo Laptop.
The dealer had assured that TVR 2.5 is compatible with Window 7. .but after installing i am only getting s-video icon ,tv and fm radio options never geting on...please help me
Computers & Internet Logo
Ekse
