Question about Sharp Televison & Video
Sharp kb-6015k won't open and closed automatically
I unplug it a couple of time already and nothing thing happens.
Posted by Wazir Khan on
  • KathleenChinn
    KathleenChinn Nov 09, 2021
    [ JOIN US ] I get paid more than $60 to $90 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $21000 from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.…………>>http://www.netcash1.com
Will not wash or spin
the two most common things are a broken lid switch or motor coupling,if you can hear the motor running but nothing else is happening you have a broken motor coupling,if it filled with water and then nothing check the lid switch,close the lid and then open it a few inches,open and close it like this a few times,if you don't hear a clicking sound when the lid opens and closes then the lid switch is bad.next time send the model number off of the washer,it will start with 110. or similar. http://www.youtube.com/watch?v=MFsvLiuTniU this will help you with the lid switch but the part number could be wrong,when you call your parts store give them the model number and you'll find it right under the bottom of the lid when it's open.http://www.youtube.com/watch?v=9K1KHEogf3c copy and paste for the motor coupling,good lick and hope this helps
Won't start. Turn the ignition and nothing. The engine light comes on and the auto theft light comes on for a few moments and goes off. I tried the couple things suggested in the owners' manual...
if nothing happens when you turn the key the problem is most likely the ignition switch and housing(had mine replaced 3 times already. firstr time at 12,000 miles) what you can try is hit key with rubber mallet while trying to turn but this would only be to get it started so you can drive to a chevy dealer(dont waste your time at any old repair shop for this). Hope this helps.
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
My Stanley 9600 opener will only work with the remote. Pressing the button in the garage, or jumping the terminals right at the two wires on the opener does nothing. This happened after an electrical...
You have shorted out your logic board. This could of been prevented with a surge protector 900 joules or higher. Whether you repair or replace get one. Stanley went out of business but you may still be able to find replacement parts online. Thanks BB
Microwave has no power
Sounds like a power board malfunction. Repair technicians usually have a minimum "bench fee" probably $50 - $75 / hour but they should be able to fix it within that hour. You will also have to purchase the power board, probably around $100 so you're probably talking about $165.00 to have it repaired.
Good Luck
I have a Sharp carousel II purchased in 1988. Never have replaced anything. It stopped working for several minutes. Worked for about a week and then stopped completely. Is it time for a...
if you have already tried to move it to another plug and same thing happens I guess you need to replace the unit. They don't last forever.
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
