Question about GE Audio Players & Recorders
What is the output power to the GE Ultrasonic 2.0 speakers . Model is HO98010
Connection to the speakers is a stereo male
Posted by Jerry Hyams on
Just need advice regarding connection to a speaker system, ( altec-lansing ADA885).
a portable DVD player usually doesn't have speaker or line outputs, if yours does just those (red and white) and connect to audio in of the altec lasnings. if no audio output connectors, use the earphone jack with an adaper (1/8 stereo male to stereo pair rca male.
2helpful
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
3answers
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
2answers
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
2helpful
2answers
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
2answers
How to hook up stereo speakers to your computer? on back of the stereo has a blue and red wires on the back.
You not only need the speaker but the amplifier [the main body of the stereo...where your Volume is] First make sure you have an input option at the back of the stereo,if your connector is different [e.g. you have stereo jack for the CPU and your stereo takes in RC only] http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html you don't have to worry about that,,,connectors are available. Attach the wire from the CPU to the Stereo,on the stereo select the input option from the front [it would be aux or any other option that corresponds to any external player attached] Play on. Let me know if any other queries...
I five klh speakers and bose amplifier, how can i connect it to my home hp pc
Perhaps you can specify which Bose amplifier you have. Presumably it drives the 5 speakers. Can you specify which computer you have? Do you have an add-on sound card? Does your computer have a 4 or more channel output? That is a different matter. Do you want the highest possible audio quality?
I'm going to assume the simplest configuration here.
1) There are two likely auxiliary input jacks for the Bose amp. One is a single 1/8" stereo jack. This jack would fit your ear bud headphones. Try this with it turned off. The other option are dual RCA jacks. These have a center opening around a cylinder about the size of a pencil. The center opening is about the size of that ear bud plug, but don't try and put it in there. The cylinder outside will have a metal ring.
2) Determine the output of your computer sound card. It is most likely a 1/8" stereo jack, so try your ear buds with it turned off. Many computers have a headphone jack and then a speaker jack. The speaker jack may be color coded green. You should be able to drive off of either of these but you will want to control the volume on your computer appropriately because the speaker output may drive too strongly for your Bose. Turn the volume up slowly.
So, then you need to go buy a cable. Here are two likely possibilities:
a) 1/8" stereo male to dual RCA male
for example: http://www.radioshack.com/product/index.jsp?productId=3449316
b) 1/8" stereo male to male
for example: http://www.radioshack.com/product/index.jsp?productId=2102949
1helpful
2answers
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • 0helpful
    Rca wsp155
    There should be a mini connector (Male) connection to 2 RCA (MALE) Connectors. You just hook the output of computer (Mini) plug to that then hookup your RCA connectors usually white and Red to the transmitter and it should work fine. Try the premium area if you need further assistance. Guru Jay
    Top GE Audio Players & Recorders Experts
    Ekse
    Rob Hill
    Rob Hill
    Joaquim Martins
    Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
