Question about Westinghouse Refrigerators
Newish westinghouse hot water dispenser showing E1
Posted by Marilyn Johnston on
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
2answers
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
3helpful
Water leaking inside freezer and forming ice in the bottom then leaks water out freezer door
you need to clean out defrost drain hole maybe have to remove back cover of frezzer i use a turkybaster with hot tap water to force hole opan
1helpful
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
2answers
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Dan Webster
Dan Webster
Ekse
Dale Copeland
Dale Copeland
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
