Question about Cameras
Stealth STC-SK742, need to re-set (change) time and date.
I need to change (re-set) TIME and DATE on my STC-SK742 Stealth trail cam
1helpful
How do I set time and date
To set the clock, have good batteries in. Slide the selector to Setup (middle setting).
Push the large right button marked MENU.
Push one of the right side buttons, above the word SHOT, these are the right > and left < buttons. Push repeatedly until you see
Set Mode
Set Clock
Set where the last Set should be outlined in dark. Now push the OK button which is the large left button.
Choose the field to update with the right side buttons > or <, once you have the one to update, use the left side up and down buttons to change the value shown until it is correct. Choose the next field with the right side < or >, update the value with the left side buttons. Only when you are completed with updating all of the date and time values, do you hit OK to set them all.
After this all pictures will have the correct time available. Though you have to choose in one of the other menus whether to show the timestamp on the picture. The picture will have the date and time associated with the file when you take the card out to view it later.
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 • Cameras
Cam says loc
The LOC message means that the slide switch on the the SD card is LOCked! The camera cannot store pictures on the SD card until the slide switch is in the correct (unlocked) position. I had this problem, as well!
I changed the batteries in my stc-tgl2m, re-set my time/date info and everything seemed fine. When I came back the next day it hadn't taken any pictures and I noticed the time/date had not changed. I shut...
Look for corrosion on the terminals that the batteries connect to. Make sure these are shiny. It sounds like you are not getting the right voltage. With a camera that old the contacts may have gotten some battery acid on them at some point.
How to set time on MDC74571W
Hold lower right button, wait for beep, release.
Click lower left to scroll through all time settings.
Click upper right button to change time/date/year.
Click lower left to save/exit.
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
