Question about Nikon Cameras
My Nikon D50 DSLR Camera images show up pink.
Why is this ? It happens on photographs taken AND also shows up in the LED Display at the rear of the Camera. Can this be fixed ? Would it require a new LED screen ? I have heard that this is a common fault which develops. The camera is about fifteen years old and recently purchased second hand but the Seller never disclosed this fault. Thank you.
Posted by Liam Lankstead on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Nikon Master
  • 41,542 Answers
Try the White Balance settings. There are 59 references in the manual. Open the link, Press CTRL+F and type ' white balance ' and scroll through. If that doesn't fix it, it will need service. My guess is that they would replace the image sensor. The display only shows what the sensor shows it.
https://cdn-10.nikon-cdn.com/pdf/manuals/dslr/D50_en.pdf
Posted on Nov 21, 2021
Can my Nikon D50 be fixed or do I need to send it for repair?
This happens during malfunction of mirror and shutter.that is when cliked shutter opens but mirror did not go up so blank monitor screen hence no image in card. Take to skilled technician to replace shutter loader mechanism.
1helpful
2answers
My Nikon N50's LCD panel does not work. Everything else works fine; theflash, shutter everything. Help Me Please?
Possible failure of the display unit of the camera is the picture taken is sowing good image after downloading on the PC.
If so the panel must be taken out and checked for voltage on the pad, the flexible strip that connects the display also can be faulty.
You will need to have some experience to open and probe into the display unit.
2helpful
Camera won't show the image on the screen when taking the pictures. I have to use the small view finder to take photos. No image on the display until the photo is taken. How do you sqitch it back to the...
You don't. The D40 works as SLRs have worked for half a century. Only more recent dSLRs (Nikon started with the D3 and D300) have the LiveView capability that lets you handle your dSLR as a point&shoot.
How to set the monochrome parameter in nikon d50 dslr camera?
There is no monochrome parameter in the D50 as oppose to the D200. You will have to convert using software.
Hope this helps.
Andrew
1helpful
I have a Nikon D50 DSLR camera. I am on vacation
R12 is not an error message, it is a normal message, in fact telling you that the camera has a 12 photo bufffer that stores the pictures as they are written to the memory card. What is most likely happening is that the camera is not able to write to the SD card. Are you using a genuine, non counterfeit memory card? There are a lot of them about,- especially from vendors on the internet selling them for 'too good to be true' prices.
Oct 18, 2009 • Cameras
1helpful
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
6helpful
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
1helpful
Photographs not being displayed
Do the pics show when you press the playback button? Does the menu display? If the display works, then check the menus to see whether image review got turned off. If the display doesn't work, it needs to be repaired/replaced.
4helpful
Nikon d80 LCD screen
Hello cherdh,
To disable those blinking spots, just press the up or down cursor keys at the back of the camera while in playback mode. You will get three different views. One shows the EXIF data (Image data) as an over lay on your photograph. Press the button again to go to histogram mode, with graphs. Press it again to go to a mode where some image data is on the bottom of the display with no blinkies on the image.
Those blinking black spots are called highlights in a photograph. They indicate the areas where your photograph is over-exposed, i.e. where there is too much light and the colours are washed out. It can be a good tool to get a good exposure. Keep clicking with different settings till you get an exposure without those blinking spots.
I hope this helps.
Satdeep
11helpful
4answers
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Cameras Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
