Question about Cameras
My stealthcam PX12FX comes up al 8's. Has new batteries and new 4gb sd card
Posted by David Meyer on
  • MichelleSaldana
    MichelleSaldana Nov 06, 2021
    Makes $340 to $680 per day online work and I received $21894 in one month online acting from home. I am a daily student and work simply one to a pair of hours in my spare time. Everybody will do that job and online ask extra cash by simply
    open this link HERE.............. http://Www.NETCASH1.Com
john h
    Top Expert:
  • Cameras Master
  • 26,185 Answers
Can notify stealth cam 877-­-269-­-8490 ..- this is manual their are no codes or troubleshooting https://www.manualslib.com/manual/837169/Stealth-Cam-Stc-P12.html?page=12#
Posted on Nov 05, 2021
Gsm Stc Px12fx Stealthcam 8mp Infared Trail Camera W 50 Range manual, please
Fixya does not supply manuals. They are available from the manufacturer of the equipment, or you can do a Google search.
Jun 06, 2019 • Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
1helpful
Tried to format new memory card for Ricoh Caplio R2. Camera just shuts down, no error messages etc. Card is an SD HC high speed 8 GB one.
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 • Cameras
13helpful
2answers
What is the largest size GB SD Card this camera will be able to accept? I just purchased an 8 GB & the camera reads a card error....I am guessing it can not handle an 8 GB...?
The DMC-FZ7 is designed to work with SD cards up to a maximum 2GB capacity (4GB in theory, but very few devices work reliably with the 4GB SD as they simply didn't exist at the time so could not be compatibility tested with most SD devices). You have tried an 8GB SDHC card which the camera is incompatible with.
The SDHC card is the same size and shape as SD but is significantly different "under the hood". SDHC compliant devices can use earlier SD cards, but devices which are not designed to use SDHC cards cannot be updated: the incompatibility lies at the basic hardware level so there is no firmware update to overcome this.
So your guess is correct, but I hope that my reply helps you to understand why. Your fix is therefore to stick with SD cards of a maximum 2GB capacity. As SDHC cards start at a minimum 4GB capacity, you have no risk of buying the wrong model.
Please take a moment to rate my answer.
3helpful
I recently bought a SanDisk 4GB SDHC card for my DXG-572V. I put it in the camera, and I turned the power on. A screen comes up saying "Format Card?". I have tried selecting both "Yes" and "No", but...
Your problem is that you are trying to use an incompatible memory card.
The DXG-572V is not SDHC compliant and will only work with regular SD cards. In theory it's compatible up to 4GB but in practice there are few standard SD devices which work well with standard SD cards above 2GB.
1helpful
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
1helpful
Can't unlock 4gb sd memory card
There's a tiny slide switch on the side of the card. Slide it to the other position and try again.
But one thing I've noticed is that you mention that the card is 4GB. As such, it's likely that this card is an SDHC card. There is also a possibility that your A540 camera is not recognizing the card as the SDHC format came out well after the A540 was designed.
If you're still having problems with your 4GB card, recommend trying again with a standard SD card (2GB or less). 2GB standard SD cards are very inexpensive, and can be found on Amazon for about $7 with free shipping.
And hang onto the 4GB card. It will come in handy again someday.
1helpful
2answers
HP5550 Storage Card
The HP h5550 is a bit old PDA , and it cant recognize it.As i know , there is actually no way to connect it.Sorry.
2answers
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
