Question about JVC Video Cameras
JVC GR DVP7E defective viewfinder monitor
The viewfinder monitor on my JVC GR-DVP7E is just showing vertical stripes in black and white. Everything else is ok. I have a GR-DVP3 which is irreparable but with a fully functioning viewfinder monitor. Would this monitor/connector fit the DVP7E?
Posted by Sjur stvold on
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
LCD screen is not showing picture, screen is coming up white and then turns to black. Unable to use! Please help.
There's already a lcd defect with your JVC, the remedy there is to replace the lcd screen. So bring it to your local service center for lcd replacement. I hope I help you in your problem.
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Model#GR-D71U
Found a customer service notice on JVC web site reporting (probable cause as a failure of CCD image sensor) and offering repair at no charge!
Only vertical Lines Appearing
You are one of the lucky ones with a defective ccd, the electronic chip in the lens assembly that makes the image. Actually if you ship this to JVC before October they are repairing this problem at no charge because of a batch failure with this part. Go to jvcservice.com to get info. Good luck, magic seadog
Gr-dvx7 jvc lcd screen is just white?
If the view finder shows the same white display. You probably have display circuit problem in the camera. Faulty CCD chip usually shows Black screen so it probably board problem or a connector problem. If you see an image through view finder then you may have defective connection from board to LCD assy. Either way it need to be looked at by a trained technician. Good luck.
Split screen and blurred vertical lines in view finder and LCD
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (customelectronics.org)
2helpful
2answers
Blank LCD screen?
Its probably a broken flex cable or the LCD is bad now because of all the flicking going on?? The flex cables about 15 bucks depending on where you get it but if your not good with really tiny electronics I would let a pro do the repair for you as you can cause alot of damage, as you could break other flex cables just taking it apart. Good Luck
JVC GR-DX25EK camcorder
JVC has issued a notice on many models that bring up a "lens cap" error. However, the GR-DX25EK is not included. The model you have posted on its page(GR-DX95) is though. This problem is still very common with models that aren't on the said list, given that and the fact that your model is from the same series, you might get some consideration from JVC. No harm in trying. The listed models get a free repair. Heres a link to the notice from JVC: http://www.jvc.com/support/notification/index.jsp?pageID=2 Good luck
Video Cameras Logo
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
