Question about Kenmore Dryers
Kenmore model 110.c66492500 dryer is not working.
There is power to the unit, but nothing is happening when I go to turn it on
Posted by michael_j813 on
  • Anonymous Nov 05, 2021
    do not post to computer help and do post to dryers
    call the service man as most folks do. you have no tools and spare parts so.... and skills in this craft
    post here
    https://www.fixya.com/troubleshoot/kenmo...
    clean the vent first. and screen for same.
    if not clean it overheats and shuts down.
I have a Kenmore dryer model# 110.C66492500, and it very nosiy. It still spins and heats but sounds very bad when we do a cycle. HELP!?
Sounds like you probably have a bad bearing somewhere. Most manufacturers offer a kit that includes the bearings and the drive belt.
Kenmore dryer model #110 C66492500 It won't shut off when we open the door in the middle of a cycle.
Either the switch that senses the door being open or closed is broken, shorted or out of it's mount, or the relay that it controls has burned or stuck contacts!
110.c66492500
Hi there this is happening to me I have tried every cycle and still no heat is there a reset button??
When I plug in the power cord nothing happens. I get power to the cord and to the switch it leads to. If you know what is wrong with my dryer please let me know. It's a Kenmore dryer model number is 110...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2010 • Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
1helpful
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Have a kenmore dryer model 110.96586400 it has a brand new heating element and will not blow hot air. what else could it be and were can i get a manual for this unit?
do you have 220 volts to receptical? if so check the thermal fuses in the back going to the element. the tub will turn on 110 volts maybe the breaker is only letting 110 volts to the dryer. i have seen it happen before.
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
