Washing Machines Logo
Question about Frigidaire Washing Machines
Frigidaire heavy duty super capacity 2 speed combonation sometimes goes through cycle fine but mostly continuously fills and drains at start S.N. XE32103237 - FEZ831CAS2
Posted by Mark Fisher on
Curt Mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 182 Answers
All front loading washers will fill and drain multiple times before it finishes. Unlike a top loader, a front loading washer will take longer to run because there is no agitator and will fill with water and drain multiple times. A front loader is more energy efficient than a Traditional top loading washing machine. A washer dryer combo will take hours to complete a cycle.
Posted on Nov 04, 2021
Fix rinse cycle
That sounds like a failed mechanical timer. Replacing that should solve your problem.
4helpful
2helpful
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
3answers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
4helpful
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
1helpful
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Top Frigidaire Washing Machines Experts
Marvin
Marvin
David Shaub
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
