Microwave Ovens Logo
Question about Panasonic Microwave Ovens
Panasonic over the stove microwave...door wont open
Posted by Anil on
Thomas Perkins
  • 15,087 Answers
Https://www.youtube.com/watch?v=xne8GQ1n5Yw
Posted on Nov 02, 2021
Lg microwave above the stove, lt is level but door wont stay open,as your putting items in it starts to close ,is there any adjustment on the door
Only gravity keeps the door in open position. You can try to tilt front down by loosening the top mounting bolts.
When I open the Panasonic microwave oven door by pushing in the door opening button, the oven starts immediately
There is evidently a fault with the door interlock switches. Don't use it as the oven may avtually be emitting microwaves with the door open.
Get a service tech to quote you for repair as it may be more economical to buy a new one, when you will have a warranty.
Do not try to repair it yourself unless you have detailed knowledge as there are components inside which can deliver a lethal shock even when the oven is not plugged in.
2answers
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
How to unlock sharp stove?
Not super familiar with Sharp Microwave ovens Convection or not,
but most microwave ovens can run into at least two reasons that they won't open and both require you to remove the cover over the whole oven - If the door has a push-button to release the door, you could find inside it has popped free of it's pivots and is not lifting up the latches on the door so you can open it, or is has actually snapped that latch. The other thing I have seen more on Panasonic microwave ovens and again moreso on the newer Inverter ovens, is that the latching assembly inside is attached to too thin a piece of metal and the metal actually bends - now your door and it's latching assembly and switches don't line up properly.
In that case you will still need to remove the cover and do your best to realign the switch assembly with the front of the microwave so that the door can click in and out easily.
Whirlpool microwave turns on and have to open door to stop it
Has it got wet inside at all? If so it could sort itself out after drying out.
But I would keep leaving the door open as you do, or replace it. Because it is a safety risk, if it came on while empty, after a while it could set fire to itself.
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
1helpful
Door wont open
After unplugging the microwave, I took the side/top panel off by removing the screws on the back*. Inside I found the piece that had broken off the part that pushes the door release. I then glued this piece back on using "Extreme Power" medium advanced performance instant adhesive. I bought this glue in a hobby shop in Richardson, Texas. I waited 12 hours for the glue to set. The door has been opening for the last two days.
*With the cover off, you can open the door by pushing the door release.
9helpful
Panasonic Inverter door stuck
The door latch mechanism is all plastic and commonly breaks. You have to take the cover off and work on it from the inside.
Top Panasonic Microwave Ovens Experts
Jaime Hernandez
Paul Bade
Steve
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
