Is it possibile to crack a Panasonic DP-UB820EGK to let hime read all region discs?
Go into the Settings of the DVD player and you should be able to switch it to 'All' regions letting you play most DVDs.
All you need to do is load up the disc. When the message pops up that says the disc will only play in a Region B or C player pops up, press "stop" on the remote control. Then press "1" on the remote, followed by "enter." This will bypass the message and load up the disc to play normally.Alternatinely, insert the disc, wait for the region warning, press OK and then 270811.
all you need to do is use the DVD Service Disc that you got when you bought your DVD player,, or go to www.panasonic.com and e-mail them about getting the codes removed so you can play overseas DVD, they sent me a disk for FREE and guess what it worked,,,, it comes with the instructions, here is what it says,,,
INSERT DISK- and confirm "STOP" is displayed...
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right coner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
the disk will be read, when finished remove disk
