Question about Logitech Audio Players & Recorders
Good Day...I had a question about my Logitech Z313 speaker wires
Posted by Willow Star Love on
ADMIN Eric
    Top Expert:
  • Logitech Master
  • 37,638 Answers
I wonder what the question was ..................... ..
Posted on Nov 01, 2021
Connections forZ313 Logitech speakers to ellipsis 8 tablet
https://www.logitech.com/en-ca/product/speaker-system-z313
The speakers have a 3.5mm stereo jack, does your tablet have a headphone output? Connnect a Male-Male 3.5mm stereo cable between the two, The Logitech does not have Bluetooth or USB, so if you do not have a headphone output, you can purchase a Bluetooth receiver, plug that into the Logitech with 3.5mm cable, and Bluetooth from the tablet to the receiver
How do i hookup logitech speakers #z313 to my emachine e202hl
The manual for your speakers can be found at http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf. The Speakers should be conected to your computer as opposed to the moniter. Disconect the small wire from the moniter to the computer and insert the plug from the speakers where it came from.
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
How to connect logitech speakers to computer
Have you gone into your control panel and checked the speaker volume ???
Start, Control Panel, Sound
Z313 one speaker stopped working
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the
computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps you
Logitech Z313 how to install it in your computer
plug these speakers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
