Question about Cameras
The memory card will insert, but not stay plugged in
I have used same memory card., it will not insert an stay plugged in
Posted by betty morgan on
  • Brad Brown Nov 01, 2021
    Hi betty morgan, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make and model of the camera?
john h
    Top Expert:
  • Cameras Master
  • 25,653 Answers
Possible retaining clip failed
Posted on Nov 01, 2021
DC shuts off when memory card is inserted
reformat the card. the card is corrupted.
Mar 23, 2014 • Cameras
2answers
I WANT TO KNOW WHERE ON THE COMPUTER DO i INSERT MEMORY CARD TO VIEW MY PICTURES
use card reader inorder to insert your memory card on the computer.
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
My mobile displays no memory card inserted when there is one
May be memory card is not inserted properly, plug it out and insert it again. and switch off and then do on your phone.
if not working by doing above...
Then there may be memory card problem, or format of memory card not supported by phone...
Do a memory card format using your PC, format it with NTFS file system. and then insert it into your phone it may start working...
Thank You
1helpful
How to i insert a memory card into my pc
Hi Good day!! Try to use a Memory card reader it is a plug and play device. you can insert your memory card in the memory card reader.
Regards:
JR
2answers
My memory card will not stay in. shoots back out
Make sure that you have the right orientation.
you may have to push a little harder since it is spring loaded. it needs to be pushed deeply in order to be latched in.
I have a LG CF360 and I am trying to insert the memory card, but I can't get it to stay completely inserted.
Hello.
Insert the memory card into the slot until the memory card is fully inserted into the slot. Note that the gold connectors must be facing down and inserted first into the memory card slot.
Hope this helps.
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
9helpful
4answers
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
I have the LG ux260 through US Cellular and I just bought the usb cord online because i want to put songs onto my phone to play as my ringtones but when i plug it in it says insert memory card, i know...
the memory card can stay in 24/7, mine does because the internal phone memory is only 16 mb ,-not many songs, but the card can hold much more.
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
